SolaraGuy.com • View topic - manual transmission fluid
Postby 01SolaraV6 » Wed Sep 27, 2006 9:07 pm
How often do you need to change this fluid and what is it called??
I heard of redline or something
2001 Solara SE V6 (5speed) Silverstream Opal
Loaded
01SolaraV6
trans. fluid
Postby Sentinel » Wed Sep 27, 2006 9:25 pm
Haynes says every 30k or 2 years: API GL-4 or GL-5 75W-90 gear oil.
This info should be in your owners manual as well.
At one time I found a .PDF that describe all toyota maintenance intervals, but can't seem to find it, nor get the hardcopy I have to fit into my modem port.
Sentinel
Postby Midias » Thu Sep 28, 2006 7:31 pm
I use mobil 1 gear oil in my solara.
Re: trans. fluid
Postby QuickSEV6 » Thu Sep 28, 2006 7:45 pm
Sentinel wrote:Haynes says every 30k or 2 years: API GL-4 or GL-5 75W-90 gear oil.
Not for a manual transmission. A manual trans is almost service free.
Try looking here for fluid
http://www.redlineoil.com/products_gear ... tegoryID=7
Postby Sleeper » Mon Oct 02, 2006 10:49 pm
Thats the oil that I use, so far its working great.
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Postby boneezy » Tue Oct 03, 2006 7:38 pm
GM Synchromesh! aka Jesus Fluid
1999 SE-V6 5spd
160,xxx miles
boneezy
