SolaraGuy.com • View topic - oil leak from head gasket???
Postby randy_1651 » Sat Oct 07, 2006 8:45 pm
Okay, I change my oil my self on my gen 1.5 2002 V6 every 3000mi. with mobil 1 10W30 I put 5qts. everytime but I see that I have an oil leak not very bad from the valve cover gasket I clean it and it comes back what should I do? ooh I have 53000mi
randy_1651
Postby TMMK Toy » Sat Oct 07, 2006 9:16 pm
sure its not a valve cover gasket?
TMMK Toy
Postby randy_1651 » Sat Oct 07, 2006 10:01 pm
yes, my bad it's the valve cover gasket
randy_1651
Postby Turbosolara » Sat Oct 07, 2006 10:20 pm
quite normal, its not expensive to fix it anyway
Postby bronzemaxell » Mon Oct 09, 2006 5:15 am
Turbosolara wrote:quite normal, its not expensive to fix it anyway
yes, probably $20 or $30 for parts, but $300 to $500 for labor if you hire a mechanic. the rear valve cover gasket is a b!tch.
bronzemaxell
Postby SleeperSolara » Mon Oct 09, 2006 6:54 am
+2.
It normal just tighten the front bolts down and just clean or wipe off the oil off.
If it starts to leak alot within a deay or week, it would be time to change it.
Postby Eye8Pussies » Sun Oct 15, 2006 8:47 pm
is it the front or the rear valve cover?
and it's not a good idea just to tighten the bolts- chances are that you may snap them and it still wont' stop the leak if there is already oil breaking the gasket seal
if it's the front valve cover, then just replace the gasket- it's a cinche. Just watch when retightening the bolts or pick up all new ones. I snapped two before I even got close to the torque specs given in the shop manual since the crush washers were 12 years old and wouldn't crush again.
If it's the rear cover gaskt.....unless you're fairly mechanically inclined, it's not worth fixing if the leak isn't much. But by the same token, if you're blown, then you don't want any leaks at all if possible and would be a good idea to fix.
Doing it is a bitch, so I can see whey labor to do it would be a good 400bucks if not more at a shop. The gasket it self is only about 25bucks.
