SolaraGuy.com • View topic - Trunk leak?
Trunk leak?
Trunk leak?
Postby {-_-} » Fri Mar 07, 2003 9:05 pm
I got a flat a few nights ago. When I reached for the jack my hand went into a puddle of water. The compartment where the jack is stored was filled. We had quite a bit of snow here last month and I am not sure if the melting snow caused this. Is this an isolated issue or has anyone else had this problem?
Thanks
{-_-}
Postby NASTY » Fri Mar 07, 2003 11:03 pm
isolated issue!
definitely never had that problem, maybe a bad seal?
'01 SLE V6
NASTY
Postby Jackass-Jeff » Fri Mar 07, 2003 11:55 pm
i had that problem in my previous car, but not the Solara.
If you ever open up the trunk when it rains, the rain, obviously, gets in it. The trunk, generally, stays cooler than the passenger compartment. Since there's virtually no heat, the water takes a long long time to evaporate (if it somehow gets to that point)...
1GR-FE ftw!
Jackass-Jeff
Re: Trunk leak?
Postby Flipside909 » Sat Mar 08, 2003 11:54 am
Do you have a moonroof?
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Re: Trunk leak?
Postby NASTY » Sat Mar 08, 2003 3:45 pm
Flipside909 wrote:Do you have a moonroof?
i dont see the relation?
'01 SLE V6
NASTY
Re: Trunk leak?
Postby Flipside909 » Sat Mar 08, 2003 5:18 pm
Drain tubes from the moonroof go into the trunk area...and exits through the rear. That's what.
www.clublexus.com
Flipside909
