SolaraGuy.com • View topic - Loose ground wire - Help pls! (1MZ - SC'd)
Postby that1mexguy » Sat Oct 14, 2006 1:55 pm
Ok today I was looking at where some of the ground wires were connected because I'm thinking about buying that ground wire kit or make my own and as I was checking them out, I discovered this ground cable attached to a huge bolt that was just sitting there, behind some cables and screwed to absolutely nothing!
See the pics below, can someone tell me where this cable is supposed to go?? I'm thinking that it was probably supposed to be removed when I got my S/C installed and they forgot or they simply F'd up and forgot to ground it back and if that is the case, I need to go bi^ch somebody out (or just plug it back if it's that easy, but I can't seem to find where it goes). Can you guys check yours out and let me know what you find out please?!?!? If you guys could some pics too I would really appreciate it, thanks!!
The 1st pic shows the ground cable I'm talking about
The 2nd pic shows where it ends and the bolt it was attached to.
that1mexguy
Re: Loose ground wire - Help pls! (1MZ - SC'd)
Postby siennasc98 » Sat Oct 14, 2006 4:06 pm
If you trace the other ground cable, it will probably lead you to one these body ground point/junction.
siennasc98
Postby CASTRO » Sat Oct 14, 2006 4:07 pm
i believe the bolt goes into your tranny. I havent looked at mine yet, but i do remember that from the tranny, it links to the engine, and from there to the body.
CASTRO
Postby that1mexguy » Sat Oct 14, 2006 5:28 pm
siennasc98 wrote:If you trace the other ground cable, it will probably lead you to one these body ground point/junction.
ok you lost me, what 'other' ground cable are you talking about? I see the ground i was showing has 2 cables, so are you saying that these 2 end points are for the same ground? Even then, I checked my engine and looks a bit different than your pic, is that from a Solara or a Sienna? thanks man
CASTRO wrote:i believe the bolt goes into your tranny. I havent looked at mine yet, but i do remember that from the tranny, it links to the engine, and from there to the body.
uh do you know where exactly? i couldnt see anything missing a huge bolt lol
that1mexguy
Postby Nyyankees3511 » Sat Oct 14, 2006 5:33 pm
It looks like ur missing a vacuum line in that pic too?
Nyyankees3511
Postby that1mexguy » Sat Oct 14, 2006 5:55 pm
uh?? where?
that1mexguy
Postby Nyyankees3511 » Sat Oct 14, 2006 6:02 pm
Right here man, i circled it in green.
Nyyankees3511
Postby that1mexguy » Sat Oct 14, 2006 7:28 pm
you have a vacuum line there??? where does it go to?
that1mexguy
Postby Nyyankees3511 » Sat Oct 14, 2006 7:47 pm
http://solaraguy.org/viewtopic.php?t=23293 , There ya go man the 5th picture shows how the hoses connect from the factory.
Nyyankees3511
Postby that1mexguy » Sat Oct 14, 2006 8:59 pm
ah i see... well that's an easy fix, thanks for looking out man.
that1mexguy
Postby Nyyankees3511 » Sat Oct 14, 2006 9:14 pm
Anytime bro. Ill have to take a look tomm morning to see where that ground goes to, ill let u kno.
Nyyankees3511
Postby that1mexguy » Sun Oct 15, 2006 9:30 am
hey man I really appreciate it, it's been bugging me all day long lol
that1mexguy
Postby ruffrydasean » Sun Oct 15, 2006 10:26 am
I didn't know you were supercharged .. nice
Click Pic for link to my Cardomain page.
Image]
ruffrydasean
Postby Nyyankees3511 » Sun Oct 15, 2006 6:13 pm
PM sent man..
Nyyankees3511
Postby SleeperSolara » Mon Oct 16, 2006 7:03 am
Did you figure it out man.
Cause after school i can go look at it for you.
Let me know.
