SolaraGuy.com • View topic - electrical problem
electrical problem
electrical problem
Postby Bravefan » Mon Oct 16, 2006 3:35 am
I have a 1999 sle. I installed my new glow guages (they look great), but at night none of the interior lights come on execpt the dome and keyring.
I also played with the hvac controls a little. Not sure if its a blew fuse or if I loosened one of the wires
Bravefan
Postby DatSRBoi » Mon Oct 16, 2006 6:03 am
Just try the fuses first. If you dont try to find the source first we arnt much of a help to you. We'll just throw allot of I thnks to you haha. I bet its just a fuse in the engine back fuse box.
Postby Bravefan » Mon Oct 16, 2006 2:46 pm
I changed a blown fuse (7.5 panel) and the interior lights are working again, but still my stock radio does not work. The only thing it does is eject cds. No lights no power on radio. any help would be great.
thank you.
Bravefan
Postby Ruski » Mon Oct 16, 2006 4:15 pm
double check your ground for your glow guages and also all connections DOUBLE CHECK ALWAYS
Postby krook » Tue Oct 17, 2006 1:11 pm
i think radio and ciggarette lighter are in the same fuse. it's a 7.5 also. check the fuses behind the coin box
krook
Postby Bravefan » Tue Oct 17, 2006 9:17 pm
I guess I messed up my radio. There is power coming through the radio harness. I am thinking of getting a cheap dvd/cd player.
Bravefan
cd
Postby NRDriver » Tue Oct 17, 2006 9:58 pm
i doubt its the radio itself. i had the same thing go on with my radio but it was the wiring harness for it. i would check for continuity on all the wires etc. it doesnt just need power to work properly
NRDriver
Postby Bravefan » Mon Nov 06, 2006 5:40 am
turned out there was a burnt wire. At best buy he replaced while hookin up my new in dash dvd. Looks almost stock at about $700 with a switch so I can watch while driving.
Bravefan
