SolaraGuy.com • View topic - problems with the gen1.....
Postby sahuddleston » Thu Oct 19, 2006 10:56 pm
there are a few things going on with the car that have me puzzled, they are pretty random, any help is appreciated....
there is a funny niose coming from the rear of the car, whenever i go over a bump it feels like the struts are rubbing on the tire or something. ive got gen2 rims with 15mm spacers, im running the stock gen2 215 55s tires. could these tires be too big and be hitting the bottom of the strut?
if my old rims were 17x7, and the gen 2 rims are 17x7, why do i need spacers for one set and not the other?
is there a secret to removing the climate controls?? ive tried to replace the bulbs and i have NO slack in the unit.. thanks for the help guys
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby krawzyazn » Thu Oct 19, 2006 11:03 pm
rsb bushing
Postby sahuddleston » Thu Oct 19, 2006 11:16 pm
hmm maybe. i just changed the RSB from street to track setting. what should i look for?
sahuddleston
Postby krawzyazn » Fri Oct 20, 2006 12:59 am
relube it
Postby CASTRO » Fri Oct 20, 2006 2:02 am
for the rim question, its because one has a different offset than the other. Meaning, the one with spacers is probable deeper than the other, while the other is the opposite and is pushed out towards the car more.
CASTRO
Postby CASTRO » Fri Oct 20, 2006 2:04 am
opps forgot, if its not the bushings, then it might be that you need your fenders rolled or cut. I had that problem with one of my sets of rims.
CASTRO
Postby Jai_Jai_Binks » Fri Oct 20, 2006 8:10 am
I had rubbing on rear's before, i wasn't so bad only when i had people in the rear - or when going over bumps...But i think this is more of a rsb relubing thingie (do you have teflon tape??)
Postby SpikedMantis » Fri Oct 20, 2006 11:34 am
I'm running Gen2 rims on my V6 Gen 1 with 15mm spacers, and I had the same problem. It was fixed when I rolled my rear fenders.
This is the space where I should write something witty or clever, hoping to show some personality.
SpikedMantis
Postby sahuddleston » Fri Oct 20, 2006 4:13 pm
thanks guys, i appreciate the input. where can i go to get my fenders rolled?
sahuddleston
Postby tweazy » Fri Oct 20, 2006 4:39 pm
I had a similar experience.
in my case, it turned out to be bad rear struts. just some thought.
tweazy
Re: problems with the gen1.....
Postby krook » Fri Oct 20, 2006 6:30 pm
stupidrunner54 wrote:is there a secret to removing the climate controls?? ive tried to replace the bulbs and i have NO slack in the unit.. thanks for the help guys
are you trying to access the back of the controls??? if you're just replacing the bulbs you can feel around the back of the unit for the 2 #74 bulbs.
otherwise, if you still want to remove the whole thing, you may not have slack on it because of the cable. peek behind and you'll see what's holding it. 4 10mm bolts hold it in.
krook
Postby sahuddleston » Fri Oct 20, 2006 11:23 pm
ok cool, will getting smaller tires eliminate the rubbing? say 225 45s?
sahuddleston
Postby Eye8Pussies » Sat Oct 21, 2006 11:28 am
chances are yes....
225/55 is more sidewall than our gen of cars originally came with- along with the different offset, I'm not surprised it's rubbing
225/45 or 215/50 should do the trick
