SolaraGuy.com • View topic - Solara shut off for no reason?
Postby rec » Fri Oct 27, 2006 10:12 pm
I was driving up a hill and i kind of pressed hard on the gas to go fast up the hill and my car just hesitated and then shut off. I pulled over to the side and tried starting it again but it would just keep trying to start. I left for a walk like 5 minutes came back started it then it just shut off on its own again so i leave again for another 15 mins come back it started and stayed on? I let it sit for a lil bit because i didnt want it to stop on the hwy and the engine was accelerating by its self the gas wire wasnt moving but some other thing was moving on the left side of the engine left back of the engine. anyone know what could of happend any ideaS? i think i might of flooded it with too much gas ? iuno tell me what you guys think :o
Mine is black.......
rec
Postby CASTRO » Fri Oct 27, 2006 10:55 pm
theres a ghost in the machine. lol, j/p
CASTRO
Postby ~Spadwaller~ » Fri Oct 27, 2006 11:16 pm
crap gas? fuel stravation from an empty tank?
~Spadwaller~
fuel
Postby Sentinel » Fri Oct 27, 2006 11:20 pm
it sounded like a fuel problem to me, but then you lost me at the end with the gas wire...
Sentinel
Postby Turbosolara » Sat Oct 28, 2006 1:32 am
you lost me ..... but sounds like fuel problem
Postby rec » Sat Oct 28, 2006 7:57 pm
i just filled up the tank its not the gas. it just start shutting off when i slam the door or hit the car with my fist it starts to shut off. any movement of the actuall car.
rec
Postby ron33030 » Sat Oct 28, 2006 8:00 pm
fuel injectors maybe not recving enough fuel. does your car have the check engine on
ron33030
Postby Turbosolara » Sat Oct 28, 2006 8:03 pm
when i am talking about fuel problem i mean fuel delivery problem, such fuel pump or fuel injector
you say the moment you slam your door, the car dies, this give a hint it is a electrical connection problem. check your battery terminal for ccorrosion
Postby Turbosolara » Sat Oct 28, 2006 8:05 pm
also if you have aftermarket alarm with ignition kill, that will give the problem too.
Postby rec » Sat Oct 28, 2006 8:08 pm
well my car just had major electrial rewiring, the whole main wiring harness was reinstalled brand new.
rec
Postby ron33030 » Sat Oct 28, 2006 8:09 pm
mybe its his alarm my was like that not realy but i just didnt start so when i took off the alarm my car was working like new yeah its the alarm
ron33030
Postby rec » Sat Oct 28, 2006 8:11 pm
ive never even used the alarm i dont even have the clicker. The wierd thing is i let the car sit for a couple mins then its fine for another 15.
rec
Postby Turbosolara » Sat Oct 28, 2006 8:24 pm
you have short wires somewhere.
ask someone to check your relay and try to do whatever stimulation you need to do. if you keep hear clicking noise from the relay, than it means you have short wires .
why did you replace your harness? and which part of harness?
sometimes when the alarm went bad, it will continuely active the ignition kill and shut off cars randomly or when it sense vibration (happened to my old neon).
Postby rec » Sat Oct 28, 2006 11:10 pm
they replaced the harness from the fuse box to wherever it goes from there to the dash.
rec
Postby Turbosolara » Sat Oct 28, 2006 11:25 pm
isnt that clear you need to go back to those guys who did the work?
