SolaraGuy.com • View topic - auto shifter replacement bulb?
Postby woa_its_j3ff » Thu Nov 02, 2006 5:05 pm
So i never knew that sle v6's gear shifter could light up. when I bought the car i never noticed it til just now. Apparently it does light up and i went to Toyota to check how much it is to replace..
140 bucks with labor
worth it or not?..
Postby bassthrive » Thu Nov 02, 2006 5:28 pm
is that a joke?
you're talking about the shifter gate, like the stick-ish thing by your cupholders?
do it yourself and save $139
pop up the black plastic surround, then you remove one screw (if memory serves) so you can pry up the entire shift gate. now you can reach and replace the little #194 bulb.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby woa_its_j3ff » Thu Nov 02, 2006 9:46 pm
bassthrive wrote:is that a joke?
it's the shifter. the thing with the |P|R|D|D2|D1|
that whole section down there is supposed to light up but it does not.
Postby DatSRBoi » Thu Nov 02, 2006 9:49 pm
Its just a bulb. They charge you 10 bucks for a bulb. which cost like 99 cent.. then the rest is labor..
Do it yourself. Your getting ripped off.
Postby woa_its_j3ff » Thu Nov 02, 2006 9:50 pm
^ any one know how to help me through this
-- the dealership told me it was a "special bulb"
and i did some research on trying to find the name/number of the replacement bulb but no luck.
I know it's a single bulb and the rest of the light is reflected (or so i heard??)..
Postby bassthrive » Thu Nov 02, 2006 10:12 pm
after you pop out the plastic surround piece (not pictured), remove the screw at the green arrow. using a large flathead screwdriver, pry up on the locations with the red arrows. it is tough (use a towel or some sort of padding where you pivot the screwdriver) but you will eventually pop the shiftgate up, from there you can access the #194 bulb.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Jon11582 » Thu Nov 02, 2006 10:25 pm
woa_its_j3ff wrote:^ any one know how to help me through this
Its a single standard 194. You can get them at Autozone for 99c for clear or 2 for 3 bucks for any other color.
Bassthrive has it exactly right. WHen your prying it up, it does take quite some pressure, a long blade screwdriver is best to get the leverage you need to pry it up
2000 Black Solara SE
Jon11582
Postby Hsakuragi » Thu Nov 02, 2006 11:16 pm
u pay me air tix, i fix it for you no charge! haha
Hsakuragi
