SolaraGuy.com • View topic - Noise coming from right rear
Postby blaK » Mon Nov 06, 2006 7:10 pm
I don't know what it is. It's not a squeek or a rattle but a knocking sound if that. So I checked the rsb and it's fine but when I push down on the right rear, I hear it. Started a few days ago and it's getting worse.
Is it my strut gone bad, spring ( i hope not, they're brand new ) or need new bushing?
Please help, thanks guys
blaK
Postby Ruski » Mon Nov 06, 2006 7:27 pm
recheck the botls i had the same noise and my top hat bolt was loose
Postby CASTRO » Mon Nov 06, 2006 8:05 pm
happened to me. It was bad bearings. Even though everything was on tight, the bearing and rear housing was shot. 350 dollars to buy replacement parts and installed it myself.
CASTRO
Postby SolaraBlue » Mon Nov 06, 2006 8:21 pm
take it back to the shop that installed your springs, if they installed them recently.
after i had my springs installed i noticed a funny knocking noise when breaking or taking off. i took it back to the shop and find out they left a screw driver on top of my rear passenger strut. i wasnt happy.
Postby blaK » Tue Nov 07, 2006 4:34 am
Thanks guys, I'm going back to the shop in the morning.
blaK
Postby bronzemaxell » Tue Nov 07, 2006 8:29 am
my solara se v6 also has a noise from the rear passenger side whenever i go over a bump or pothole at low speed, first i thought it was the wheel bearing when i did a search on this forum, and i kept driving it for more than 2 years with that noise, one day, i decide to take a look at it, so i took out my wheel, then caliper, and rotor, i found the cup and spring that hold the parking brake shose fell off the pin, my guess was it was that small spring and cup bouncing around inside my rotor making those noise, and once i put them back, the noise went away.
bronzemaxell
Postby blaK » Wed Dec 20, 2006 6:51 am
Fixed it!!!!!!!!
It was the RSB, one of the screws were so loose that my friend could loosen the nut with his hands. He grabbed a wrench and tightned it.
Done
blaK
