SolaraGuy.com • View topic - She's Hurting
She's Hurting
She's Hurting
Postby GooseXRS » Wed Nov 08, 2006 5:05 am
Okay. here is why I say my solara is hurting. The seat belt light turns on and off but is on most of the time. The starting problem where it idles at 235rpm. Shes rubbing her ass on her rear shoes, the front driver strut didnt set into place right, and her brakes are squeeking when they are fine.
Makes Me Wanna Cry
Any suggestions of what to do?
Thanks Guys/Girls
Andrew
"The defense department regrets to inform you that your sons are dead because they were stupid. "
- Goose
GooseXRS
Postby MikeATL » Wed Nov 08, 2006 7:31 am
maybe it has something to do with your avatar?
MikeATL
Postby Biggi_e » Wed Nov 08, 2006 7:31 am
lol
Postby rollaevo99 » Wed Nov 08, 2006 7:40 am
LOL LOL LOL :drinking:
Postby crispone » Wed Nov 08, 2006 7:41 am
MikeATL wrote:maybe it has something to do with your avatar?
Bwaaaaaaahhhhh ha ha ha ha!!!
OUCH!! (Not NICE, yo.... BUT, that WAS a little funny for an a.m. chuckle...)
Seriously, dude.... hope you get those kinks worked out...
PS --> Judging by the "scene", you must be a "bakery pirate"?
- crisp :evilbat:
Postby GooseXRS » Wed Nov 08, 2006 6:59 pm
Thats it. Im changing it to titties to be like everyone else. I just wanted something different and funny. Its not me though its one of my best friends.
- Goose
GooseXRS
Re: She's Hurting
Postby Turbosolara » Wed Nov 08, 2006 7:21 pm
GooseXRS wrote:Okay. here is why I say my solara is hurting. The seat belt light turns on and off but is on most of the time. The starting problem where it idles at 235rpm. Shes rubbing her donkey on her rear shoes, the front driver strut didnt set into place right, and her brakes are squeeking when they are fine.
Makes Me Wanna Cry
Thanks Guys/Girls
Andrew
1. check connection of the weight sensor under the seat, maybe you can just disconnect it. Or just take out the clock along with the seat belt indicator
2. low ideling, there could be many reason. check your enigine oil, spark plugs, idel valve in the throttle body, or clearn up the throttle body
3. rear camber off, you need aligment soon, or your will have bad wear on your tires or blow your tire
4. might have be strut mount problems like other members here
5. brake squeek, might be because you used ceremic brake pad or you actually lost the inner side brake pad
Postby GooseXRS » Thu Nov 09, 2006 11:08 am
First I like the hard gay sig. Second I think its more the seat belt conection because when I push it down it stops and my seat belt light is in the gauge cluster. I already cleaned the throtle body. I need to roll my fenders because my alignment isnt off. Its rubbing because the offset I am running. I want them rolled and pulled out a little. Does any socal people know a place for somewhat cheap. Also Is there a place where I can get aftermarket strut mounts?
Thanks For the Help
Andrew
- Goose
GooseXRS
Postby Turbosolara » Thu Nov 09, 2006 4:41 pm
you didnt mention if those problems are driver side or passager side and if you know the cause why dont you just fix it?
you can try TWS "the wheel supply" at walnut.
Postby GooseXRS » Thu Nov 09, 2006 10:59 pm
I dont know how. also my brake light comes on until I hit the beakes. Not the a.b.s. light but the light that says BRAKE in the gauge cluster.
- Goose
GooseXRS
Postby Turbosolara » Fri Nov 10, 2006 12:08 pm
your brake fluid is low
Postby Turbosolara » Fri Nov 10, 2006 12:10 pm
Postby crispone » Fri Nov 10, 2006 12:33 pm
GooseXRS wrote:I dont know how. also my brake light comes on until I hit the beakes. Not the a.b.s. light but the light that says BRAKE in the gauge cluster.
Could be your mechanical switch behind the brake pedal... (I'm recalling on ANOTHER car... assuming they are similar...) sometimes, when a vehicle gains some age, this pedal switch's "return spring" can no longer hold the contacts off... wherein the connection circuit "closes" intermittently... or more regularly as time passes. (Could also be the fluid... by if that's up, then look at the switch...)
BTW, Goose... don't change your avatar on our account... I'm not interested in seeing "titties" in place of what you got. "Bread-Pirate" is a MUCH better visual to associate with the persona you sear upon us through your posts than "bone-headed-testosti-loaded-shallow-dweller-female-objectifier"... Hard to picture ANY of you in here in a thong or splittin' cleavage while you deliver the lines we have to read... (except ToyoChick, perhaps...)
HeII, how about "Dread-Pirate-Robert"? You could be from Penzance, for all I care... you're welcome here WHATEVER yer fettish is.
