SolaraGuy.com • View topic - About quickshifter
About quickshifter
About quickshifter
Postby Russian Guy » Thu Mar 13, 2003 11:24 pm
Unfortunately I didn't find picture with manual but for A/T
Any questions - ask :lol:
1MZ-FE TRD S/C. 2 BLITZ NUR Spec mufflers. SPA Boost/Fuel + Revotec water/oil/volt gauges. BLITZ Powermeter ID III, Denso IK 22 Iridium, TRD brake lines, TRD rear sway bar, fuel pump upgrade
Russian Guy
Postby Russian Guy » Thu Mar 13, 2003 11:27 pm
Of course we can't compare the mechanism but the idea is to dismantle it step by step. It's not so complicated... :P
Russian Guy
Postby Russian Guy » Thu Mar 13, 2003 11:29 pm
AHA - I've found the mechanical one :lol: :lol: :lol:
33504F KNOB SUB-ASSY, SHIFT LEVER (FOR FLOOR SHIFT)
33530F LEVER ASSY, SHIFT (FOR FLOOR SHIFT)
33282A PIN, LEVER LOCK (FOR CONTROL SHIFT LEVER)
33527 LEVER, CONTROL SHIFT (FOR FLOOR SHIFT)
33527B BUSH (FOR CONTROL SHIFT LEVER)
33534E CRANK, SELECTING BELL, NO.2
33534F BUSH (FOR SELECTING BELLCRANK NO.2)
33534G WASHER, PLATE (FOR SELECTING BELLCRANK NO.2)
33557A COVER, SELECTING BELLCRANK DUST, NO.1
33558 COVER, SELECTING BELLCRANK DUST, NO.2
33574A RETAINER, SHIFT CABLE GROMMET, NO.1
33574B RETAINER, SHIFT CABLE GROMMET, NO.2
33608 SUPPORT SUB-ASSY, SELECTING BELLCRANK
33821 CABLE TRANSMISSION CONTROL SHIFT (FOR FLOOR SHIFT)
33821B GROMMET, NO.2 (FOR TRANSMISSION CONTROL CABLE)
33821C WASHER, PLATE (FOR TRANSMISSION CONTROL CABLE)
33822 CABLE TRANSMISSION CONTROL SELECT (FOR FLOOR SHIFT)
Russian Guy
Postby Russian Guy » Thu Mar 13, 2003 11:36 pm
33208G RING, E (FOR REVERSE RESTRICT PIN)
33211 FORK, REVERSE SHIFT
33211B ROLLER (FOR REVERSE SHIFT FORK)
33212A FORK, GEAR SHIFT, NO.1
33213B BOLT (FOR SHIFT FORK SET)
33213G FORK, GEAR SHIFT, NO.2
33214G FORK, GEAR SHIFT, NO.3
33228B PIN, RING (FOR REVERSE SHIFT ARM BRACKET)
33232A PIN, SLOTTED SPRING (FOR SHIFT HEAD SET)
33232F HEAD, GEAR SHIFT, NO.1
33240 BRACKET ASSY, REVERSE SHIFT ARM
33242 SHAFT, GEAR SHIFT FORK, NO.1
33242D PIN, SLOTTED SPRING (FOR SHIFT FORK SHAFT)
33242J BUSH (FOR SHIFT FORK SHAFT)
33243A SHAFT, GEAR SHIFT FORK, NO.2
33251A LEVER, SHIFT, INNER NO.1
33251B PIN, SLOTTED SPRING (FOR SHIFT INNER LEVER)
33252A LEVER, SHIFT, INNER NO.2
33261C SHAFT, SHIFT & SELECT LEVER
33261L BUSH, BIMETAL FORMED (FOR SHIFT & SELECT LEVER SHAFT)
33266C PLATE, SHIFT INTER LOCK
33266E RING, E (FOR SHIFT INTER LOCK PLATE)
33276E SEAT, SELECT SPRING, NO.1
33276F SPRING, COMPRESSION, NO.1 (FOR SELECT RETURN)
33277 SEAT, SELECT SPRING, NO.2
33277A SPRING, COMPRESSION, NO.2 (FOR SELECT RETURN)
33280 PIN ASSY, REVERSE RESTRICT
33283D PLUG (FOR REVERSE RESTRICT PIN)
33283G PIN, SLOTTED SPRING (FOR REVERSE RESTRICT PIN)
33290 BALL ASSY, LOCK, NO.1
33528B COVER, CONTROL SHAFT
33528C SEAL, OIL (FOR CONTROL SHAFT COVER)
33528D RING, O (FOR CONTROL SHAFT COVER)
33528J BUSH, BIMETAL FORMED (FOR CONTROL SHAFT COVER)
33531B BOOT, DUST (FOR SHIFT & SELECT LEVER SHAFT)
31126 BOOT, CLUTCH RELEASE FORK
31204 FORK SUB-ASSY, CLUTCH RELEASE
31210 COVER ASSY, CLUTCH
31230 BEARING ASSY, CLUTCH RELEASE
31232A CLIP, RELEASE BEARING HUB
31236B SUPPORT, RELEASE FORK
31250 DISC ASSY, CLUTCH
Hope it would definitely help somebody :wink:
Russian Guy
Postby Russian Guy » Thu Mar 13, 2003 11:38 pm
Finally... :angel:
This the link to these pictures. Some words are in Russian but it's not hard to surf this site
http://www.elcats.ru/toyota/engine.asp?tid=74&tregion=U
Russian Guy
Postby Russian Guy » Thu Mar 13, 2003 11:44 pm
OOOps it doesn't work
try this:
http://www.elcats.ru/toyota/?urlid=27
You should choose in the left column your VIN
or in right column at first row you choose year/month of production (it;s not so important really because they have only 1998-2001 solara :cry: )
at the second row you choose type of transmission - mechanical or AUTO
at th third row you choose the desposition of your steering wheel =)
any questions - don't hesitate to ask me :fadein:
Russian Guy
Postby Peter » Fri Mar 14, 2003 1:36 am
great post, we should start the diy forum as suggested by someone earlier. this is very useful for people, that way we dont have to keep emailing diagrams :D
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby Russian Guy » Fri Mar 14, 2003 2:51 am
Actually i'm going to download these pictures with description from their server and then post them on my site so everybody can download a zip.file with all necessary info about their solaras :evil:
Just give me some time :P I'll try to complete the task till monday :fadein:
Russian Guy
