SolaraGuy.com • View topic - where did i go wrong??????
Postby SolaraBlue » Wed Nov 15, 2006 10:42 am
hey boys and girls. ok, so i put my stock headlights back in today. they work great.
the problem im having is with the corner lights. everything is hooked up but they wont light up. they blink when i turn on the blinker but other than that theyre off....
also my alarm wont lock or unlock the car. it doesnt do anything now....
anyone know what i may have done wrong? and how i can fix it??? any help is much appreciated!!!!
Postby Jai_Jai_Binks » Wed Nov 15, 2006 10:53 am
Ensure your corner bulbs are correctly (dual fillament). A while back i had ghetto taped my corner bulbs to do what you describe.
As far as your alarm and rest of the stuff...???? don't know....check your fuses.
Postby rollaevo99 » Wed Nov 15, 2006 11:04 am
Jai_Jai is correct...... dual fillament..... but then again I hope you didn't pull out some wires...may be?? It happens to me before lol :drinking:
Postby SolaraBlue » Wed Nov 15, 2006 11:12 am
rollaevo99 wrote:Jai_Jai is correct...... dual fillament..... but then again I hope you didn't pull out some wires...may be?? It happens to me before lol :drinking:
would they still blink if i pulled a wire? or if the fillament was wrong?
hmmm.....
Postby rollaevo99 » Wed Nov 15, 2006 11:28 am
hmmm.....
on my corolla it has 2 split wires.....the other wire got pulled out for the park light, so the blinker is till working.......or pull out the bulb and look closer if one of the fillament is broken.
Postby PXLpainter » Wed Nov 15, 2006 11:33 am
Whaddyamean they still "Blink"?
The "Blinker" relay is in the driver's kick panel and will still make sound as well as the rest of your indicators (inside and out) - even if you have no bulbs at all in the front.
Postby SolaraBlue » Wed Nov 15, 2006 11:33 am
a friend told me to take it to auto zone and they could run a diagnostic to see where the problem is. is this true? i thought the only way they could do that is if the "check engine" light came on.
Postby SolaraBlue » Wed Nov 15, 2006 11:41 am
PXLpainter wrote:Whaddyamean they still "Blink"?
they blink..... i dont know how else to explain it..... the bulbs only light up when i have the blinker on.....
Postby lilm » Wed Nov 15, 2006 12:26 pm
alll you did was change the lights?
lilm
Postby SolaraBlue » Wed Nov 15, 2006 12:33 pm
^^^i changed the whole headlight and corner assembly.
Postby Turbosolara » Wed Nov 15, 2006 12:44 pm
just try to use the another side of light bulb to experiment if the bulb is faulty.
your keyless entry might be short or been disabled
Postby SolaraBlue » Wed Nov 15, 2006 12:51 pm
Turbosolara wrote:just try to use the another side of light bulb to experiment if the bulb is faulty.
ive tried different bulbs on both sides.....
Postby WTF?? » Wed Nov 15, 2006 12:54 pm
wish I could just hand you the extra sets of 1157's that I have to test it... But did you also try swapping the bulbs from pasenger to driver and vice versa? Do your Hazards work?
EDIT: nevermind you just answered my question
When you turn your parking lights on, only the tailights turn on??? very odd
Retired... its been fun Image
WTF??
Postby SolaraBlue » Wed Nov 15, 2006 1:05 pm
WTF?? wrote:wish I could just hand you the extra sets of 1157's that I have to test it... But did you also try swapping the bulbs from pasenger to driver and vice versa? Do your Hazards work?
yeah tails turn, hazards work.... blinkers work.....
Postby Turbosolara » Wed Nov 15, 2006 1:10 pm
is your parking light not work at all (4 corners), did you check the fuse?
