SolaraGuy.com • View topic - Battery Replacement
Battery Replacement
Battery Replacement
Postby LatinDragonXJC » Mon Nov 27, 2006 12:22 pm
Hey guys, just wanted to ask you guys..... Its time for me to change my battery (cuz it keeps loosing charge and I'm tired of getting jump started). And I wanted to know what types of batteries do you recommend? And how much do they usually cost? I've been researching and I'm not sure about CCA and RC for the Solara.
From the searches I've done on here, I see that Optima is a favorite, how much do those usually cost?
LatinDragonXJC
Postby ~Spadwaller~ » Mon Nov 27, 2006 1:01 pm
Optimas are over kill unless your running a sound system, cost is around 100+
Interstate battery cost like 50-60 bucks and IMO better than stock
~Spadwaller~
Postby NeFaRiOuS_SLE » Mon Nov 27, 2006 3:22 pm
^^ Werd
Another thing to check is your alternator, which if it isn't charging properly, that may be your culprit.
Postby jhenty » Mon Nov 27, 2006 3:28 pm
interstate
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby unbalancedwood » Mon Nov 27, 2006 8:02 pm
Is it the alternator or the battry if when you roll up your windows the lights dim?
unbalancedwood
Postby LatinDragonXJC » Tue Nov 28, 2006 1:59 am
Thanks for the replies, I'm guessing its the battery. I usually notice small things like the lights dimming when I lower my window, but I'll check that again.
I guess my question now will be, have any of you gotten your alternator replaced? Was it costly?
LatinDragonXJC
Postby solaraheno » Tue Nov 28, 2006 8:58 am
i replace my batt, but when i lower my window, the dash board light got dim....
solaraheno
Postby LatinDragonXJC » Tue Nov 28, 2006 1:21 pm
Personally I thought all cars did that when you lower the windows, it would drag a bit from the interior lighting but not much.
LatinDragonXJC
Postby ~Spadwaller~ » Tue Nov 28, 2006 1:47 pm
Dont forget you can get your battery tested free at AutoZone and I think the alternator too
~Spadwaller~
Postby LatinDragonXJC » Tue Nov 28, 2006 2:02 pm
~Spadwaller~ wrote:Dont forget you can get your battery tested free at AutoZone and I think the alternator too
oh yeah? I tried doing that my local Pep Boys, they told me they can test the battery for free if I bring it to the counter.........but charge me 21 bucks if its in my car, along with the alternator. I'ma go check AutoZone then, its usually my last choice, cuz of the horrible customer service. Thanks.
LatinDragonXJC
Postby bronzemaxell » Wed Nov 29, 2006 8:24 am
recently my diehard gold battery doesn't hold charge, i've already changed the battery that came with the car 4 years ago, and instead of replacing the battery, i bought a battery charger/reconditioner from walmart for $60, reconditioned it two times, now the battery holds charge again. i am not sure if that is a good long term solution, but so far, car still starts fine.
bronzemaxell
Postby Eye8Pussies » Wed Nov 29, 2006 11:24 am
try tricklecharging
and it's the alternator when you run a motor/regulator off the battery since the drain on the battery considerable while it is in use
Postby LatinDragonXJC » Wed Nov 29, 2006 2:37 pm
bronzemaxell wrote:recently my diehard gold battery doesn't hold charge, i've already changed the battery that came with the car 4 years ago, and instead of replacing the battery, i bought a battery charger/reconditioner from walmart for $60, reconditioned it two times, now the battery holds charge again. i am not sure if that is a good long term solution, but so far, car still starts fine.
I'm doing this right now. I got it at 10amp for the next 2 hours before I go to class. I tried going to Autozone to get it checked out, I called beforehand, they told me it was free and to bring my car in. Once I'm there, they say , they don't do that (basically too lazy to come outside), I was right about the horrible customer service. Thanks for the replies. Hope charging it works.
LatinDragonXJC
