SolaraGuy.com • View topic - Timing Belt
Timing Belt
Timing Belt
Postby GooseXRS » Mon Nov 27, 2006 11:33 pm
Does anyone here know if and how to check to see if the timing belt was replaced on my car. Its running bad. :(
Thanks
Take Care
Andrew
"The defense department regrets to inform you that your sons are dead because they were stupid. "
- Goose
GooseXRS
Postby GooseXRS » Tue Nov 28, 2006 2:45 pm
Anybody know?
- Goose
GooseXRS
Timing Belt check
Postby PDX SuperSolara » Tue Nov 28, 2006 3:23 pm
You have to take off the plastic cover or at least loosen it up enough to pull it back though that won't tell you much. If the cam Vs crank timing is off you will get a check engine light.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby Jai_Jai_Binks » Tue Nov 28, 2006 3:23 pm
Honetly, there are a few ways:
1. is there a sticker on the timing belt cover (well my camry has a sticker bu the tech forgot to put the plastic adhesive on teh sticker so the numbers faded, but the bank sticker remains)
2. for me i could hear when my timing belt needed replacement..call me anal.
3. press down to see how much do it really move, check the edges to see if they look new...
question is what are you experiences that makes you want to doubt this?
GL
Postby GooseXRS » Tue Nov 28, 2006 7:26 pm
Its just lagging alot and and it idles really low like 300-500 rpms. Sometimes less. It feels like im loosing power. My Porsche did the same thing before the timing belt snapped (luckily when I was starting it so no damage was done) I will look for the sticker tomorrow. I just thought there would be like a website or maybe a phone number.
Thanks Alot guys.
Take Care
Andrew
- Goose
GooseXRS
Postby crispone » Tue Nov 28, 2006 7:41 pm
Man, I never heard of your car beginning to run poorly because a timing belt was needing changed.... I can't imagine how "stretched" it would have to be to effect the performance that much.... maybe I've just never BEEN there? On the OTHER hand, mine failed when the car was running like a "raped ape".... (I always change them well in advance ANYWAY.... at least, ever since I SNAPPED one at the top of fourth headed South on I-75 into Dayton on my '84 Supra at about 97k miles.... I was just about to shift at redline, then.... like the "Back to the Future" Delorean lost motor/power/everthing just before the run for the lightning bolt...)
My experience has been that the only timing belt related SYMPTOM I have had was when a camshaft "jumped time" and I had to reset it... this happened a couple times at around 200k miles on the Supra when the cam bearings began to "gall" just a little and "squeal" at startup, until the teeth would "pop a tooth" or more and then the car ran like SHLIT! (It was OBVIOUS...)
I suspect some OTHER issue, ignition, fuel delivery, timing.... ON TOP of perhaps a timing belt change. My rule of thumb would always be.... if the mileage warrants a timing belt change, and you don't KNOW if it's been changed, CHANGE IT. Don't test your fate on chance on consumables of such magnitute in terms of vehicle operation. (I don't know about these Solaras, but the Toyotas generally have enough clearance NOT to bend valves if the belt breaks.... whereas on a Honda, you are SCREWED if you snap a belt...)
Good luck.
-crisp :evilbat: :drinking:
Postby GooseXRS » Tue Nov 28, 2006 7:53 pm
Well I have 124k on the car. I am also going to replace the injectors and the spark plugs to see what happens. Any suggestions on spark plugs? Also can I use gs300 1mz-fe injectors? I dont see why not.
Thanks again
Take Care
Andrew
- Goose
GooseXRS
Postby Mr_Chunks » Wed Nov 29, 2006 2:28 am
dude....
you had a porsche?
Mr_Chunks
Postby Jai_Jai_Binks » Wed Nov 29, 2006 9:34 am
GooseXRS wrote:Also can I use gs300 1mz-fe injectors?
And you had a porsche...do show some pics
Postby GooseXRS » Wed Nov 29, 2006 11:32 am
Sorry, typo. es300 injectors. ill post pics of the porsche later. Shes dead. She blew up next to south coast plaza with me in it. Ill tell the story at the meet if people want me to.
- Goose
GooseXRS
