SolaraGuy.com • View topic - Ebrake light
Ebrake light
Ebrake light
Postby sbsolara84 » Thu Nov 30, 2006 11:07 am
I did a search and didn't find anything...
Do you guys know why the ebrake light occasionally turns on while driving?
The e-brake is off, made sure of that many times.
it often goes on when i accelerate hard.
No mods to the engine, brake, or tranny.
it's been ongoing for a couple of days now, thought i should check it out just in case.
sbsolara84
Postby **PoshPepper** » Thu Nov 30, 2006 11:11 am
I know it means something, and your owners manual will tell you... I think it may mean your brakes need to be checked, but I cannot remember off the top of my head...
I know someone on here can provide a positve answer to this question....
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby sbsolara84 » Thu Nov 30, 2006 11:58 am
^^ yeah did a little research on google, i think it's a loose connection or something is up with my brakes
sbsolara84
Postby michaelwgng » Thu Nov 30, 2006 12:04 pm
the same thing happened to me a month ago, it usually means that your brake fluid is low.. add brake fluid and u should be fine.. if not then there is something wrong with your brake system.. get it checked out asap..
MIKE
Mike
michaelwgng
Postby 99V6solaraSE » Thu Nov 30, 2006 1:01 pm
what he said ^^^
i remember there being a thread about that sometime before
99V6solaraSE
Postby GooseXRS » Thu Nov 30, 2006 1:27 pm
^^^^ What they said. I just had that happen 2 weeks ago. Put some fluid in and blamo no more light.
"The defense department regrets to inform you that your sons are dead because they were stupid. "
- Goose
GooseXRS
Postby s15lara » Thu Nov 30, 2006 3:00 pm
theyre all right. just add some brake fluid and the light will go away. now the reason for you needing brake fluid is b/c your pads are probably a lil low and the piston pushes the pad to the rotor b/c its wearing down a lil. check your pads and make sure that theyre not extremely low (which theyre probably not that bad yet) and that should solve your prob. in conclusion...just add brake fluid and after such a big job have yourself a :drinking:
almost there...what do you think?
s15lara
Postby vinnie the sex » Thu Nov 30, 2006 3:29 pm
i posted this am thing lol
vinnie the sex
Postby sbsolara84 » Thu Nov 30, 2006 7:55 pm
Great, thanks alot guys
sbsolara84
Postby blaK » Wed Dec 06, 2006 6:35 am
Oh snap, Im going thru the same thing. I'll put some fluid and post if it worked.
Thanks guys
blaK
Postby blaK » Wed Dec 06, 2006 8:02 pm
So I went to the mechanic and he said it's a sensor.
Brake fluid fine and plenty of pads left.
blaK
