SolaraGuy.com • View topic - Smoke from Radiator
Smoke from Radiator
Smoke from Radiator
Postby sbsolara84 » Fri Dec 01, 2006 8:11 pm
I just did a coolant exchange, car had over 64k on it, it was about time.
I drove it home, and i when i got out, there was smoke coming out of the radiator.
did the F*** up, did some thing leak, or is it normal after the exchange.
sbsolara84
Postby anttarz » Fri Dec 01, 2006 8:28 pm
your thermastat could be shot, is the car over heating as well (not just smoking)? Could be a leak, radiator could have a small crack, cap could be shot. Look under the hood and see where its coming from.
Any sort of smoke coming from under the hood is not good.
anttarz
Postby SleeperSolara » Fri Dec 01, 2006 8:28 pm
Hmmm.....
That's the first i've heard that.
Postby made in china » Fri Dec 01, 2006 8:37 pm
Probably just coolant that spilled over the radiator during the service steaming off. I wouldn't worry about it unless it keeps doing it.
Gettin' pirate eyed.......
2002 BSP SE V6 5 Speed
TRD RSB
5000K HID Headlights
3000K HID Foglights
Gen 1.0 Tails
Optitron Lexus Cluster
made in china
Postby sbsolara84 » Fri Dec 01, 2006 10:53 pm
^^^that's what i thought it was. well watevers, i'll take it back to em 2morrow and have em check it out anyways.
sbsolara84
Postby Mr_Chunks » Sat Dec 02, 2006 12:24 am
if it keeps doing it have them check the hoses
also, with our cars if you floor it or accelerate hard, coolant surges and spills over
if they over filled it then it might be spilling onto your headers. If they overfilled it its just a matter of siphoning out some of it.
Mr_Chunks
Postby CASTRO » Sat Dec 02, 2006 1:24 am
even if they overfilled it, theres no way that would happen because it would first go out of the overflow reservoir.
CASTRO
Postby crispone » Sat Dec 02, 2006 9:18 am
Firstly, I am going to assume you are meaning "STEAM", and not "SMOKE". The two would indicate VERY DIFFERENT issues... if you have SMOKE, there may be a much more serious issue than described below....
Sometimes the coolant system needs to "equalize" after a drain/fill... It may just need to "cycle" a couple times up to full temp, even if the pressurized system is "spilling" over into the overflow. Sometimes, the overflow bottle can "overflow" until the "HIGH/LOW" point balances out. This process may also require "BURPING" the system, or "PURGING" the air within the water jacket/loop within the cooling loop. This is accomplished by starting and warming up the engine (from a cold state) with the radiator cap OFF. Initially, the coolant will just "sit there" unaffected by the running engine.... once the coolant/engine begin to come up to temp., the thermostat will open, and coolant will begin to circulate... (you'll see it "agitating"...let it circulate for a few moments...) After a few more moments, the coolant should "rise" and begin to "burble out" of the radiator. Now it's fully circulating and expanding from the heat. PUT THE RADIATOR CAP BACK ON! You've just "burped" your system. What is happening here is, there may be "AIR POCKETS" within the cooling system loop. Especially if it has been FULLY DRAINED and filled. Sometimes, this "AIR POCKET" can get to the "water pump" impeller area, and cause "CAVITATION", or "free-air pumping", wherein no HYDRAULIC action is taking place. In this state, the system will begin to overheat, until the "cavitating" air pocket in the system is "bled" or "burped" from the system...
I also think the thermostat COULD be "sticking" closed. This sometimes happens just after a change if it is OLD... or may just "start happening" without any change... You should observe your initial "start-up/warm-up" period... where the temp. gage is coming up to the point where it usually "levels off", or holds steady once everything is up to temp.... watch closely, and as you begin to drive, does the temp. gage go ABOVE the usual point for a short while... then come back down again after a few minutes of driving at temp? (Sometimes, if the thermostat is sticking "badly", the temp. will shoot up to RED or FULL gage temp. for a little bit, then all of a sudden, the thermostat "pops" open, and drops back down.... if the thermostat is NOT popping open at all, then it must be replaced IMMEDIATELY, as you will overheat and damage the motor.
(What is going on with the thermostat is this: When you first start a car, the engine is cold. In order to generate warmth "quickly" to bring the engine temp. up to PROPER operating temp. the thermostat is "mostly" or "all the way" closed. This means little or no coolant is circulating... until temp. is within thermostat range, then it pops open, and begins to circulate.)
The OTHER thing that comes to mind is your radiator cap may be worn or not "seated" well after the change. Some coolant may be getting out around the cap and "evaporating off" as steam.
Phew! Did I just type all that?
Actually, be careful.... I don't really know ANYTHING about cars.... but I DID sleep at a HOLIDAY INN EXPRESS last night!!!
Postby PXLpainter » Sat Dec 02, 2006 9:56 am
crispone wrote:Actually, be careful.... I don't really know ANYTHING about cars.... but I DID sleep at a HOLIDAY INN EXPRESS last night!!!
Dood - you're such a wise-arse! LOL!! :lol:
I too was thinking... "SMOKE?!! From the RADIATOR???" ;)
Postby sbsolara84 » Sat Dec 02, 2006 3:01 pm
^^my bad, steam.
yeah i guess the idiots just spilled the coolant all over the place when they did the exchange. it was just "STEAMING" off.
it's gone now.
thanks
sbsolara84
Postby crispone » Sat Dec 02, 2006 3:48 pm
Good to hear....
Now... hopefully, the verbose tutorial on cooling system troubleshooting serves SOME useful purpose for someone else out there with a REAL issue!! LOL :lol:
I had fun thinking about it, anyway.... it actually made my stay at the Holiday Inn Express THAT MUCH MORE meaningful... :wink:
Postby sbsolara84 » Sat Dec 02, 2006 6:25 pm
^^uhmmmm yeah. get over yourself dude.
sbsolara84
Postby NeFaRiOuS_SLE » Sat Dec 02, 2006 7:54 pm
crispone wrote:it actually made my stay at the Holiday Inn Express THAT MUCH MORE meaningful... :wink:
Lemme guess... It involved Bambi and some :drinking:.
Postby crispone » Sat Dec 02, 2006 8:08 pm
....aaaaaahhhhhhhh....... Guinness in a Heini stein....
....brooding boys and beverages.... the hypocrisy of "hip's" and hops...
-crisp :evilbat: :drinking:
Postby NeFaRiOuS_SLE » Sun Dec 03, 2006 12:59 am
^^^^^^^^ROFLMFAO
...With a shot glass full of Bailey's and Jameson's, then ya got's ya some mighty fine chuggin' chocolate! (Irish Carbomb)
