SolaraGuy.com • View topic - 01 defect
01 defect
01 defect
Postby 01RDSLE » Tue Mar 18, 2003 1:17 pm
bummer man, my car just turned over 36,000 miles, and the first defect occurred on my car.
would you believe, a burned out tail light? jeeesh :drinking:
Wishin for warmer weather!!!
01RDSLE
Postby Jackass-Jeff » Tue Mar 18, 2003 1:23 pm
damn, you better take it to a qualified shop! :wink:
1GR-FE ftw!
Jackass-Jeff
Postby DavPak » Tue Mar 18, 2003 1:30 pm
xravexboix wrote:damn, you better take it to a qualified shop! :wink:
see if you can take it to our "master toyota diagnostician" redhottoyo in atlanta!
'02 Solara S/C'ed V6 5-spd
DavPak
Postby happy_aggies » Tue Mar 18, 2003 1:50 pm
Gosh... y'all... :lol:
01RDSLE,
Just read ur manual, it should have the instructions to change that bulb.
happy_aggies
Postby Yanks0114 » Tue Mar 18, 2003 2:37 pm
LOL. You know its a quality car when you consider a burned out bulb a defect :D
Postby Jackass-Jeff » Tue Mar 18, 2003 3:18 pm
I think that would cause more defects :lol:
1GR-FE ftw!
Jackass-Jeff
Postby ChiTownSolara » Tue Mar 18, 2003 8:33 pm
my left tail burned out last week too, so i went to autozone to pick up a new bulb and right next to the regular bulb there were these special Red LED bulbs that will fit perfectly. i installed them instead of the standard bulb and they are SO cool! when u hit the break, they are Much brighter than stock bulbs, plus they give that expensive LED look that are on a lot of high end cars nowadays. only one downside, they are like $16 for a pack of two. but it says they are supposed to last the life of the car plus they look much better so i thought is was worth it.
ChiTownSolara
Postby Jackass-Jeff » Wed Mar 19, 2003 12:02 am
ChiTownSolara wrote:my left tail burned out last week too, so i went to autozone to pick up a new bulb and right next to the regular bulb there were these special Red LED bulbs that will fit perfectly. i installed them instead of the standard bulb and they are SO cool! when u hit the break, they are Much brighter than stock bulbs, plus they give that expensive LED look that are on a lot of high end cars nowadays. only one downside, they are like $16 for a pack of two. but it says they are supposed to last the life of the car plus they look much better so i thought is was worth it.
sounds good... I think I'll pick up a pair in a few years when my lights burn out :D
1GR-FE ftw!
Jackass-Jeff
poor quality?
Postby Guest » Wed Mar 19, 2003 9:25 am
Is there a recall notice for this? Or at least a TSB? Whats happening with Toyota quality control these days? I've had 4 Toyotas total, and never had to replace a bulb! :wink: :wink: :wink: :wink:
Guest
I hope this dosen't effect the 02 models!
Guest
Postby Flipside909 » Wed Mar 19, 2003 10:04 am
Anonymous wrote:I hope this dosen't effect the 02 models!
Even if it does, it's something too small to worry about. Now if it were mechanical, then i'd be a bit more concerned.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Jai_Jai_Binks » Wed Mar 19, 2003 11:10 am
:lol: you all postwhores!
:drinking:
Postby Jackass-Jeff » Wed Mar 19, 2003 12:50 pm
ADMIN
please lock the post. we're not benefiting anymore from this... plus we wouldn't want to fill up space on the server w/ useless posts. (sorry for the post, but this is probably the fastest way to get it locked w/o spamming the admins :D )
1GR-FE ftw!
Jackass-Jeff
Re: poor quality?
Postby Yanks0114 » Wed Mar 19, 2003 1:20 pm
Anonymous wrote:Is there a recall notice for this? Or at least a TSB? Whats happening with Toyota quality control these days? I've had 4 Toyotas total, and never had to replace a bulb! :wink: :wink: :wink: :wink:
Thats really not something to be worried about. They arent going to Issue a TSB for a bulb that reguarly burns out.
