SolaraGuy.com • View topic - rattling noise
rattling noise
rattling noise
Postby AzN_DrAgoN48 » Tue Mar 18, 2003 6:01 pm
i have this rattling noise comming from my passenger side. it comes whenever i go over a pot hole or if i have my music loud with a deep bass. anyone know what it is? its really annoying me
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Re: rattling noise
Postby Yanks0114 » Tue Mar 18, 2003 6:04 pm
AzN_DrAgoN48 wrote:i have this rattling noise comming from my passenger side. it comes whenever i go over a pot hole or if i have my music loud with a deep bass. anyone know what it is? its really annoying me
My glove box has actually been rattling a little lately, and its bothering me. It goes away when I apply pressure to the front of it. Also i would check if you have anything in thepocket on the door.
Re: rattling noise
Postby Flipside909 » Tue Mar 18, 2003 8:04 pm
Ahh yes, the all too common glovebox rattle. That thing wasn't really built well or paid attention to during prototype testing.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Re: rattling noise
Postby DavPak » Wed Mar 19, 2003 5:25 am
Flipside909 wrote:Ahh yes, the all too common glovebox rattle. That thing wasn't really built well or paid attention to during prototype testing.
well, it IS just a glovebox!!
'02 Solara S/C'ed V6 5-spd
DavPak
Re: rattling noise
Postby Flipside909 » Wed Mar 19, 2003 10:03 am
Yes it's JUST a glovebox, but yes, it's latch is so weak, it will start rattling even on the smoothest roads. That's called poor quality control right there...specifically to the plant it was made at. Cambridge.
www.clublexus.com
Flipside909
Re: rattling noise
Postby NASTY » Thu Mar 20, 2003 6:17 pm
I HAVE THIS TOO! it drives me insane!
mine sounds like its coming from under the passenger seat (maybe the fore/aft adjustment). ive told my dealer over and over, and theyve 'fixed' it three times, but its still there!
'01 SLE V6
NASTY
Postby Jackass-Jeff » Thu Mar 20, 2003 7:55 pm
maybe i havent gotten to the point of it yet... but have you tried locking it? i keep mine locked so that may help...
1GR-FE ftw!
Jackass-Jeff
Re: rattling noise
Postby krook » Thu Mar 20, 2003 8:18 pm
NASTY wrote:I HAVE THIS TOO! it drives me insane!
it's your passenger seat sliding rails. if you pull that lever on the passenger side, you'll notice that the WHOLE seat gives and slides back; you have to hold the seat up to the front with your hand to let your passengers put the dead body in the back.
when you do that, you usually push the seat all the way back. and THAT'S what causes the rattling! it's the lever on the bottom which rattles. to remedy it, just move the seat up a notch.
krook
Postby AzN_DrAgoN48 » Fri Mar 21, 2003 9:20 pm
thanx i think that help... and locking the glove box. my stupid friends always push the seat back all the way. it really annoys me :x
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Re: rattling noise
Postby xyntax » Fri Mar 21, 2003 9:54 pm
krooked Solara wrote:it's your passenger seat sliding rails. if you pull that lever on the passenger side, you'll notice that the WHOLE seat gives and slides back; you have to hold the seat up to the front with your hand to let your passengers put the dead body in the back.
You know what Krooked, I'm glad you mentioned this. I've had this rattling problem for months now and I never thought it would be the seat sliding rails. When somebody's sitting on it, the rattling stops. What you suggested works! The rattling sound is gone now. I hope it never comes back. Thanks!
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Re: rattling noise
Postby NASTY » Fri Mar 21, 2003 10:28 pm
Xyntax wrote:What you suggested works! The rattling sound is gone now. I hope it never comes back. Thanks!
moving it a notch stops the rattling?
hmm...ill try it next time
'01 SLE V6
NASTY
Re: rattling noise
Postby krook » Sat Mar 22, 2003 5:51 pm
yeah, guys....that sh!t was driving me BONKERS!!! NASTY, yep...just move the seat up a little if it's all the way at the back notch of the seat rail.
unfortunately, the sound will always be there; especially if you frequently store dead bodies, or young hotties in the back seat area where movement of the pass. seat is necessary. :roll:
krook
Postby aerostar33 » Mon Jun 09, 2003 8:10 am
I have a rattle too that I think is coming from the glovebox area. I tried locking it and playing with the seat rails like you guys suggested, but its still there. It becomes noticeable at 40 mph and louder as I go faster. Any other suggestions aside from bringing it to the dealer?
aerostar33
Postby 01RDSOLARA » Tue Jun 10, 2003 8:30 am
I had the same BSR upon reaching speed, and it would go away at low MPH.
nope not the glove box nor seats. not this time . . .
yep, stopped in a rest area, and found the stone guard loose behind the passenger front wheel and mud guard. Seems the noise cropped up through the car body and manifested itself as a seat and glove box issue.
come to find out, after thinking about it for a while, remember hitting a monster chuck hole a couple weeks earlier in a rain storm. jeeesh.
further, your wiring harness and washer hose may be loose as well and rattleing in the front passenger wheel well. yep, I had this problem too, and it was tricky fixen this one.
anyhow, my 2C worth.
01RDSOLARA
Postby zwilk777 » Sat Sep 05, 2009 7:00 am
I had the exact same problem with a speed sensitive rattling noise. After reading the post I checked under the front wheel hub and the debris guard was loose. I snapped it back in place and tightened it and the noise is gone.
Thanks for the help, I probably would have never thought to check there.
zwilk777
