SolaraGuy.com • View topic - Smoke Coming from vents
Postby rec » Thu Dec 21, 2006 4:26 pm
Sorry to bug everyone but lately when i turn on my heater, smoke starts to in through the vents and it also looks like smoke coming from where the engine is, kinda towards the dash. This only happens when i turn the heater on . Anyone know why this would be happening?
Mine is black.......
rec
Postby hskrsolara » Thu Dec 21, 2006 4:39 pm
ever spill any oil on your engine...headers?
hskrsolara
Postby kingkakyle » Thu Dec 21, 2006 4:41 pm
probably some oil burning on ur engine
Postby rec » Thu Dec 21, 2006 4:42 pm
nope i havent spilled any oil at all. Its wierd too because if you stand right in front of the car facing the hood the smoke is coming from the back of the engine. Does my radiator have anything to do with it. ? And Also do solara radiators take water or all coolant ? or half and half ?
rec
Postby Solorange » Thu Dec 21, 2006 5:10 pm
Doesnt sound like a radiator issue. But check the coolant levels to see if they are low. Solara use 50/50 mix too.
Postby Nyyankees3511 » Thu Dec 21, 2006 5:10 pm
You need to use a 50 water and 50 of toyota coolant which is red.
Nyyankees3511
Postby Eye8Pussies » Thu Dec 21, 2006 9:20 pm
if there is steam coming out of your vents as well, you may want to take a look at your heater core
Postby rec » Fri Dec 22, 2006 1:49 pm
no steam but where is the heater core located? Maybe theres something wrong with that.....
rec
Postby Down2TheC » Fri Dec 22, 2006 3:03 pm
Does it smell like a campfire? Check for smouldering leaves and junk. Been there.
If it smells electrical then perhaps your fan motor is frying out. But not if it's only with heat and not with cold air.
We need more info...
Either way, spend $15 and get an extinguisher for the trunk.
Down2TheC
Postby Fratsgotasolara » Fri Dec 22, 2006 3:48 pm
well if you have a lot of water in there it could be evaporating water, so check your evaporator drain, and i don't know if yours is new enough to have a cabin air filter but if it does check to see how clean it is
"You may not know me, But your girlfriend does!" -Delta Chi OSU
Fratsgotasolara
Postby crispone » Fri Dec 22, 2006 4:40 pm
Your information so far leads me to suspect the heater core also... have you checked to see if you are consuming some coolant? Get FULLY up to temp and then switch heat on HIGH temp at LOW fan level, and see if this causes "STEAM" (appearing to be "smoke"). Note whether or not your windshield FOGS from this.
Postby rec » Sun Dec 24, 2006 12:16 am
crispone wrote:Your information so far leads me to suspect the heater core also... have you checked to see if you are consuming some coolant? Get FULLY up to temp and then switch heat on HIGH temp at LOW fan level, and see if this causes "STEAM" (appearing to be "smoke"). Note whether or not your windshield FOGS from this.
well i put coolant in the tank because i had none in there :X then i checked the next morning and it was a lil low so doesnt that lead to the heater core ? maybe its leaking somewhere ? I havent seen any leaking. After putting coolant it hasnt been smoking. But the coolant in the tank keeps getting lower.
rec
Postby NeFaRiOuS_SLE » Tue Dec 26, 2006 12:12 am
There might be a leak somewhere in the radiator that is in the upper area; might not leak in your driveway but might happen when you're on the streets.
