SolaraGuy.com • View topic - Engine tempatured
Engine tempatured
Engine tempatured
Postby facevedo17 » Fri Dec 22, 2006 5:30 pm
Hi has anyone noticed or have a similar thing happen to them ...I recntly noticed since it was brought to my attention when driving the engine tempatured is usually higher for example ok you have the guage right you have cold then the middle and hot and then the red line extremely hot ...its usually past the middle but pretty close to the red prob bya quarter its that normal does the age of the car miles driving might have something to do about that ????
facevedo17
Postby crispone » Fri Dec 22, 2006 5:45 pm
Unless you have a malfunction in the performance of your gage, you should not see an increase in temperature regardless of the age/mileage on your car, unless there is a problem. Heat is indicative of an issue somewhere.
Things I would consider:
1) Coolant level incorrect (low)
2) Thermostat sticking
3) Timing incorrect
4) Water pump (or belt)
5) Head gasket leaking
6) Crack in head
Not necessarily in that exact order, but it would be a good starting point.
That's what comes to my mind right off hand....
Note: Since you are STOCK and N/A, #5 & #6 are not AS likely as an inducted motor.... but age, or durability driven factors such as the first 4 are definitely suspect....
-crisp :evilbat: :drinking:
Postby crispone » Fri Dec 22, 2006 5:49 pm
^^^ My initial suspicion is #2.... or the pump and belt...
Postby Eye8Pussies » Sat Dec 23, 2006 2:48 am
I would say thermostat as well
Postby Turbosolara » Sat Dec 23, 2006 2:53 am
all i know is you are f**ked, it should not pass middle line. maybe your coolant temperature sensor is malfunctioning but most likely you might just have a bad thermostat
Postby Jai_Jai_Binks » Sun Dec 24, 2006 12:52 am
god, i has to read it three times to understand the dude's q. Anyone know grammer or when to place punctuations....
Postby facevedo17 » Tue Dec 26, 2006 5:31 pm
sorry I was in a hurry
facevedo17
