SolaraGuy.com • View topic - starting problems
starting problems
starting problems
Postby juggalotus40 » Thu Dec 28, 2006 11:45 am
Hi everyone im sorry if this was talked about in the past but i couldnt find anything searching
my 2000 v6 doesnt start when i turn the key it sounds as if you were to put a card through a fan the radio works and the battary eye is gree so i guess its charged although i have been using that battery without charging for 5 years i think it might be the starter but i dont know much so any help would be good
2000 SLE V6
juggalotus40
Postby SPF 0 » Thu Dec 28, 2006 12:39 pm
If I'm reading what you wrote correctly (please use punctuation in the future), it sounds as if you have a starter with a "flat spot."
The solution, IIRC, is to simply replace the starter.
SPF 0
Re: starting problems
Postby Jai_Jai_Binks » Thu Dec 28, 2006 1:03 pm
juggalotus40 wrote:i have been using that battery without charging for 5 years
^^ Time for new battery dude. Simple...see if your battery connections are coroded to see if you want to replace them.
Postby SPF 0 » Thu Dec 28, 2006 1:34 pm
My thoughts are that he's not getting weaking cranking; he's getting a clicking sound.
To me, that points to a starter issue.
juggalotus40, does your car start with a jump?
SPF 0
Postby Midias » Thu Dec 28, 2006 1:49 pm
juggalotus40 wrote:Hi everyone im sorry if this was talked about in the past but i couldnt find anything searching
the original battery on my 01 v6 just went out. It had a green eye and plenty of water but still would not start the car. If you can start with a jump you need a new battery. I got mine from advance auto parts about 80 dollars for the titanium series with about 725 cca
Postby **PoshPepper** » Thu Dec 28, 2006 2:02 pm
The "clicks of death" usually indicate a starter issue... (as already mentioned)...
If the battery was dead the radio wouldn't be working...
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby Midias » Thu Dec 28, 2006 2:05 pm
**PoshPepper** wrote:The "clicks of death" usually indicate a starter issue... (as already mentioned)...
Battery could have enough power for the radio and not the starter if it was on its way out mine did that.
Postby SPF 0 » Thu Dec 28, 2006 3:40 pm
Lucky for him, it'll be pretty easy to figure out which is which.
SPF 0
Postby facevedo17 » Thu Dec 28, 2006 4:21 pm
just had my battery replace ....damn cables where corroding on the Mofo.... starts up fine now ... when I first got the sign I got all scared ..pop the hood saw that corrosive acid ...clean it up and had it like that for 2 weeks till I got tired everytime it didn't want to start , I had to check my cables and clean them it was a pain in the ass
facevedo17
Postby **PoshPepper** » Thu Dec 28, 2006 4:33 pm
I stand corrected... I know everytime a battey has failed on me, nothing has worked... LOL... maybe just my luck
Milt's OTHER ride
**PoshPepper**
Postby juggalotus40 » Fri Dec 29, 2006 10:21 am
thank you all for the replies my car will not start even with a jump
i think i will replace both the battary and the starter.
has anyone replaced a starter before and aprox how much does one cost
2000 SLE V6
juggalotus40
Postby campfire9 » Fri Dec 29, 2006 12:16 pm
Don't forget to wash a new battery with baking soda and water because acid is uaually all over the case. Also get a paper cup with 1/2 baking soda and 1/2 water and put the cable leads in and let them soak for awhile. I use a toothbrush to clean them off. After the battery is in and cables connected I use a battery protector (Krylon) spray to keep the cables free of corrosion.
campfire9
Postby Midias » Fri Dec 29, 2006 12:32 pm
good advice personally I use spray lithium grease on my terminals
Postby SPF 0 » Fri Dec 29, 2006 12:32 pm
I don't know where you live (i.e., how cold it is in your area), but it's quite possible your battery has more than fair amount of serviceable life left.
SPF 0
Postby juggalotus40 » Fri Dec 29, 2006 2:17 pm
i live in MA
has anyone changed a starter before?
2000 SLE V6
juggalotus40
