SolaraGuy.com • View topic - SOMETHING WIERD JUST HAPPENED
Postby solaraluv » Thu Dec 28, 2006 9:42 pm
I just drove about 5 miles to a friends house, dropped something off got back into my car and my ABS light is on and the TRAC light is blinking! what could be wrong? if anyone knows please let me know im very scared right now.
Loved by few hated by many
solaraluv
Postby solaraluv » Fri Dec 29, 2006 6:38 am
Ok I dont get it, this morning I started it up and now the lighs are off??? what the hell!!!
solaraluv
Postby krook » Fri Dec 29, 2006 1:53 pm
what a flirt! it was winking at you...
krook
Postby NeFaRiOuS_SLE » Mon Jan 01, 2007 10:03 pm
Seems like a busted ABS speed sensor.
Postby anttarz » Mon Jan 01, 2007 10:22 pm
NeFaRiOuS_SLE wrote:Seems like a busted ABS speed sensor.
Most likely a sensor
anttarz
Postby facevedo17 » Wed Jan 10, 2007 4:26 pm
interesting same thing happened to me not to long ago I though it was my brake fluid ...abs sensors ....got get that check ....
facevedo17
Postby solaraluv » Thu Jan 11, 2007 8:12 am
It hasnt happened since then.
solaraluv
Postby woa_its_j3ff » Thu Jan 11, 2007 8:47 am
it could be a sensor, it happened to me a few times before too, one main reason was because my battery was dying, and it was causing it to do that..
check the battery, and the sensor as well.
Postby facevedo17 » Thu Jan 11, 2007 6:19 pm
yeah thats right the battery was acting up to but that was because my connections weren't on tight enough ...
facevedo17
Postby woa_its_j3ff » Thu Jan 11, 2007 9:58 pm
is their batt acid around the connectors? clean that off, or get good clamps.
have autozone or something run a diagnostic test. it might help
Postby solaraluv » Fri Jan 12, 2007 12:11 pm
woa_its_j3ff wrote:it could be a sensor, it happened to me a few times before too, one main reason was because my battery was dying, and it was causing it to do that..
^^Where is the sensor located?
solaraluv
Postby solaraluv » Mon Jan 22, 2007 5:52 pm
Ok, it came back again then went off. It started Back up today on my way home this evening until I made the tires spin then it went off again.
solaraluv
Postby woa_its_j3ff » Mon Jan 22, 2007 6:12 pm
solaraluv wrote:Ok, it came back again then went off. It started Back up today on my way home this evening until I made the tires spin then it went off again.
ok and why you make the tires spin?
check the battery like i said, is it alright? nothing wrong with it?
Postby solaraluv » Mon Jan 22, 2007 6:26 pm
^^^Well, i think its ok. i have the red top optima about 8 month old and the connections are good.
solaraluv
Postby woa_its_j3ff » Mon Jan 22, 2007 8:13 pm
oh it's an optima?? i find it weird then..
optimas aren't known for such things so im not exactly sure if it's the battery man..
