SolaraGuy.com • View topic - How to ??
How to ??
How to ??
Postby Ruski » Tue Jan 02, 2007 8:03 pm
Im having problem with my ignition coils and i wanted to check the resistance to see which one is bad. does anyone know how to do this? i don't want to replace all off them
Thanks
Re: How to ??
Postby siennasc98 » Tue Jan 02, 2007 8:50 pm
Ruskimafia wrote:Im having problem with my ignition coils and i wanted to check the resistance to see which one is bad. does anyone know how to do this? i don't want to replace all off them
Thanks
Do you have an OBDII code reader? What is the original CEL code?
You can also switch the location of the coils and if the CEL code changes (when compared to the original) then you can identify which coil is bad.
siennasc98
Postby Ruski » Wed Jan 03, 2007 5:06 am
see the thing is its on a sienna 00 and it dosnt through a code but sparks where changed and wires problem stopped then came back. cylinder 6 was misfiring then it was fixed now the problem came back
