SolaraGuy.com • View topic - Transponder Key
Transponder Key
Transponder Key
Postby Texas Tornado » Tue Jan 02, 2007 10:59 pm
I need help with a problem in programming another Master Transponder Key. I tried all the search functions and found a lot of info., but none of it worked in my situation.
By the way; I have a 2003 SLE with (DEI) Viper 791 alarm system with the 555u By-pass module installed in my car, which is where the installer put my second master key.
I bought another key from a good seller on eBay, which is the one I am trying to program.
Thanks for any help anyone could give me.
2003 Solara SLE 3.0 V6 - Red
Very clean adding mods.
Mods: TRD Body Kit, Injen CAI, Optima Red Top, TRD RSB, TRD FSB, TRD Oil Cap.
Texas Tornado
Postby lilm » Wed Jan 03, 2007 7:52 am
lol think you gotta find directions for your alarm.....but since its a key you would think the same rules apply........call the installer?
lilm
Postby RichD978 » Wed Jan 03, 2007 8:32 am
you wont need another transponder key, any key would work since you got it bypassed
RichD978
Postby krook » Wed Jan 03, 2007 1:11 pm
guys, i think he's just trying to program another key--not bypass it so the alarm works.
if you're trying to program a 3rd key go to the dealership and tell them you also have a 2nd key in the bypass module. All 3 have to be programmed together.
krook
Postby lilm » Wed Jan 03, 2007 6:02 pm
there are directions on here to do that...how much do you think the dealership will charge him......when i got my car they wanted 45 dollars a key just to program...and of course i had to use the keys the dealership seals LOL needless to say i got my keys and programmed them myslef
lilm
Re: Transponder Key
Postby Texas Tornado » Wed Jan 03, 2007 7:48 pm
lilm111 wrote:lol think you gotta find directions for your alarm.....but since its a key you would think the same rules apply........call the installer?
no; I don't need directions for my alarm. Obviously; you didn't understand my post.
RichD978 wrote:you wont need another transponder key, any key would work since you got it bypassed
that wasn't my question either; I'm only trying to program another key, question was do you think my by-pass module is preventing me from programming another key?
krook wrote:guys, i think he's just trying to program another key--not bypass it so the alarm works.
Krook, you're on the money; :D do you think the DEI By-Pass module is preventing this problem? The key works in the doors and will go into the ignition but; won't start the car, and it's a Master Key with the chip. Thanks for your response.
lilm111 wrote:there are directions on here to do that...how much do you think the dealership will charge him......when i got my car they wanted 45 dollars a key just to program...and of course i had to use the keys the dealership seals LOL needless to say i got my keys and programmed them myslef
I have the directions from the Dealer; this procedure is not working for some reason on my car.
I guess; you didn't understand my post either.
I thought this forum was to help others; :( I know I would if that time arises.
Oh well; thanks for all the responses anyway.
Texas Tornado
Re: Transponder Key
Postby MCOjerry » Wed Jan 03, 2007 8:56 pm
Texas Tornado wrote:I thought this forum was to help others; :( I know I would if that time arises.
I think that no one really knows the answer, it' not that they don't want to help. Seems like people are trying.
Postby lilm » Thu Jan 04, 2007 8:01 am
ya what i was thinking was if your orginal directions from toyota dont work.....maybe you have to program it through your aftermarket alarm but it seems that a by-pass module is supposed to by-pass it....lol...
actually if you search for 555u By-pass module you should get your answer...i dont have a aftermarket alarm...but it seems that these by-pass modules are used for remote start http://www.caraudio-caralarms.com/bypass-module.html
Obiviously; i dont think you understand your alarm.
lilm
Postby Jackass-Jeff » Thu Jan 04, 2007 8:20 am
A maximum of 4 keys can be registered... I assume you're the original owner... but if not, then removing excess keys may be necessary.
Now that I think of it, the DEI module is probably doing this. Since a master key is technically always inserted due to the key's presence... remove the key from the module and it should probably work. The ECU is probably detecting that the master is still inserted and is going nuts.
Jackass-Jeff
Re: Transponder Key
Postby **PoshPepper** » Thu Jan 04, 2007 10:13 am
People were trying to help you... not everyone is going to know the answer to every problem posted on this forum... and comments like these arent going to get you any more help... :roll:
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby DaveMush » Fri Jan 05, 2007 4:27 pm
As long as the key is cut to fit the ignition cylinder, I dont really think you will have to program the key. The ECU thinks that there is a key inserted at all times. Why would it care if the key really is / is not programmed to work if it already sees a key in the ignition...
177Hp/186Tq Stock and OBDII compliant...
Dyno
DaveMush
Postby Dawgz » Fri Jan 05, 2007 8:15 pm
DaveMush wrote:As long as the key is cut to fit the ignition cylinder, I dont really think you will have to program the key. The ECU thinks that there is a key inserted at all times. Why would it care if the key really is / is not programmed to work if it already sees a key in the ignition...
Wrong, completly wrong...
Here are the directions to program ur new key...u have to have ur master key tho
http://www.solaraguy.org/viewtopic.php? ... mme+remote
Postby lilm » Fri Jan 05, 2007 8:48 pm
omfg read my link :evilbat:
hes right, completly right.....what do you think that the by-pass module is for
the by-pass BY-PASSES the transponder in the car tricking the ecu to think that the key is always in enabling the car to start the car with remote start.
lilm
Postby Dawgz » Fri Jan 05, 2007 10:44 pm
lilm111 wrote:omfg read my link :evilbat:
no, hold on, i have the clifford rsx 3.5 with the bypass module, but that module has the Transponder key inside it with the "key part" cut off, just the RF chip is there.
BUT if u put a key thats the exact same as my master that doesnt have the transponder, then the car will not start.
THIS is why im saying this.
