SolaraGuy.com • View topic - Throttle lag=bad tranny???
Postby solaraluv » Tue Jan 09, 2007 9:36 am
I got off the phne with a service advisor at my local Toyota dealer and I had explained to him about the lag that I get at times. Now I know this issue has been discussed before about this problem with the gen 1 v6, but I just cant get over the fact that this dude automatically assumed it was may tranny without evern looking at the car! I have been driving log enough and had many cars to know when the tranny is on its was out. Can someone please get me some info that will resolve this matter, I want to go to the dealer today at some point and I just want to have all the right info. Thanks
Loved by few hated by many
solaraluv
Postby SleeperSolara » Tue Jan 09, 2007 10:02 am
Have you checked your fuel filter, or air filter.
That might cause some lag.
I think i'm right.....
I'm only guessin' from what you have said.
Postby solaraluv » Tue Jan 09, 2007 10:18 am
^^^the air filter and Pcv valve has been changed within the last weeks the fuel filter was changed about 30k miles ago.
solaraluv
Postby Hsakuragi » Tue Jan 09, 2007 11:08 am
clean ur throttle body?
Hsakuragi
Postby SolaraBlue » Tue Jan 09, 2007 11:16 am
spark plugs/wires?
Postby PXLpainter » Tue Jan 09, 2007 11:32 am
Hey - did somebody slip an '06 Gen 2 ECU in your car when you weren't looking??!! :o
:lol: :drinking:
Postby solaraluv » Tue Jan 09, 2007 12:54 pm
^^this weekend ill try to change the plugs and wires and clean the throttle body but thoes back plugs are gonna be a bi-tch to get to though. so no one thinks its a transmission issue?
solaraluv
Postby 99V6solaraSE » Sun Jan 14, 2007 8:58 pm
yea i feel a slight lag sometimes.. but its hasnt been bad enough for me to worry.
how bad is ur lag exactly?
99V6solaraSE
Postby tybowman » Tue Feb 13, 2007 7:55 pm
my solara started doing the same thing ... it turned out to be the cati had it replaced and no more prob
tybowman
Postby Turbosolara » Tue Feb 13, 2007 8:00 pm
what is cati?
Postby PXLpainter » Tue Feb 13, 2007 8:00 pm
tybowman wrote:my solara started doing the same thing ... it turned out to be the cati had it replaced and no more prob
The "cati"??? Wazzat?
Postby Nyyankees3511 » Tue Feb 13, 2007 8:03 pm
I assume he means catlytic converter but dont take my word on that lol.
Nyyankees3511
Postby tybowman » Sun Feb 18, 2007 4:36 am
ha ha ... yea that was definatly a typo ... cat as in catlytic converter lol
tybowman
Trans slip
Postby PDX SuperSolara » Mon Feb 19, 2007 2:55 pm
If you don't have enough fluid in your automatic transmission it will slip sometimes or have a delay engaging gears. Check that first. On several occations I have had a customer come in for a transmission replacement because the dealer or another shop said it needed one, just to find a low fluid level.
If that's not it, the A541E transmission has been known to fail in odd ways, like no upshift or downshift, or a bad ECU (the ECU controls shifts). Usually they don't just wear out. They just fail in weird ways, though the dealer is just a glorified parts exchanger, they won't ever rebuild a tranny they put in only a factory reman unit so the dealer will never be able to tell you why it failed if it was internal. The ECU is replaced under warranty though for 8 years or 80K miles due to known problems. I've had mine done.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby orlin03 » Mon Feb 19, 2007 3:39 pm
Since you'll be doing the rest of the tune up anyway, another fuel fitler wouldn't be a bad idea; you never know if you've picked up some junk in there. Also, have you ever done a trans service? I know mine has a drain plug, and I plan on using it often (to get the most life out of the filter); old nasty fluid has been known to put drag on an engine, which could make it feel sluggish. Trans services are probably the most overlooked maintenance procedures out there, and they go a long way in preventing future problems.
orlin03
