SolaraGuy.com • View topic - Burning Oil
Burning Oil
Burning Oil
Postby thook » Sat Jan 13, 2007 10:48 pm
I bought a 02 Solara se v-6 with 35,000 from Towbin Dodge "the King of Cars" just outside of Las Vegas a couple of months ago for 13000 (because of the low mileage). I thought that since this was a toyota (and they last forever) it would be a good car to put 100,000 miles on and sell cheap to my teenage son.
It is burning 1 quart of mobil 1 synthetic oil every 2-3 tanks of gas, which I think is excessive given the low mileage. It has started to blow a tiny bit of blue smoke on startup. It also has a rattle coming from the rear wheel area like something is loose (local shop double checked me and nothing is loose). Any ideas of what I can do for these issues that won't break the bank? Thanks.
thook
Postby NeFaRiOuS_SLE » Sat Jan 13, 2007 11:18 pm
Blue smoke? It usually means that you have oil sludge buildup in your engine block... Fortunately for you, there is an oil sludge campaign out. Check out below:
http://www.solaraguy.org/viewtopic.php?t=29668
Postby ThatVietGuy » Sun Jan 14, 2007 1:16 am
Rear rattle could be a bearing or suspension mounts.
ThatVietGuy
