SolaraGuy.com • View topic - good OBDII software
good OBDII software
good OBDII software
Postby tdiman » Wed Jan 17, 2007 7:08 am
I'm looking for some good software, or something that can read and reset codes at the least. I currently have a laptop with software and cables for Fords and VWs, but nothing for Toyota. Does anyone have a good suggestion for cable and software for Toyotas? I don't need the fully featured stuff, and free software would be the nicest :D
tdiman
Postby tdiman » Fri Jan 19, 2007 1:04 pm
no one, eh?
What does everyone use when they get a CEL? I did a little research and it appears that all foreign imports use a 9141 ISO standard for OBDII. That means that my VW softare uses the same protocol as a toyota.
if only I could just get software to do completely generic OBDII scanning for all OBDII compliant cars, I could avoid 3-5 software packages. That would make my life a little easier. :drinking:
tdiman
Postby indiglosolara » Fri Jan 19, 2007 2:29 pm
Scan Gauge 2...
This is what I am using in my xB..
It lets you scan and clear CEL codes.
Best money I have ever spent....
Plus it also now lets me monitor my real time Water Temp, RPM, VOLT, Intake Air temp and tons of other things....
I used this to clear another member here who had a CEL...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby facevedo17 » Mon Feb 05, 2007 7:58 pm
Quick question on this one I saw this so called software at a Walmart store it goes for less than 100 dollars ...it said on the cover help pass inspection read codes and able to clear them ...?
so if i have a Cel for any reason and manage to clear the code can't going thru inspection be a problem ? im a little lost on this product but curious before I invest on it
What is its purposed ?
facevedo17
Postby lilm » Mon Feb 05, 2007 8:51 pm
you can use the obd II reader to cler the code......but depending on the code it might just come back in five minutes
lilm
Postby CASTRO » Mon Feb 05, 2007 9:02 pm
indiglosolara wrote:Scan Gauge 2...
Word on that! I've been a scanguage owner since the first model (and I still have it) that I recently bought (2) of the revised ones and now each of my cars have it. Best deal on a scanner/gauge system ever.
CASTRO
Postby Mole » Tue Feb 06, 2007 12:54 am
i have the Autotap.
hooks into the laptop via usb.
