SolaraGuy.com • View topic - what's the cause of this sound?
Postby woa_its_j3ff » Wed Jan 17, 2007 10:41 pm
So here's the deal.. when I drive over any bump, my car makes a clunnk sound, i know that its normal on all cars but on in it seems like i dont know, maybe struts? no clue, but it just takes the ride very harshly as well over potholes, bumps, anything really.
do you know what the cause of it may be? and what I can do to fix this problem?
thanks.
Postby SolaraBlue » Wed Jan 17, 2007 11:15 pm
id think struts or strut mounts....
do you have aftermarket springs?
Postby anttarz » Wed Jan 17, 2007 11:27 pm
Sounds like a shot mount, they dont really last. Have you replaced the struts recently?
The best thing is to get the car on a lift. Makes sure the strut assembly is tight. Makes sure everything is sittin right. --try to twist the spring, moving control arm, mount. Also check swaybar links.
anttarz
Postby woa_its_j3ff » Thu Jan 18, 2007 8:15 am
SolaraBlue wrote:id think struts or strut mounts....
no i dont at the moment, they are still stock.
Postby SolaraBlue » Thu Jan 18, 2007 10:04 am
then id do what anttarz mentioned and check the mounts and struts. thats most likely your culprit....
Postby woa_its_j3ff » Thu Jan 18, 2007 10:41 am
ah okay.. it was like that when i bought it at the dealership, i didnt think much of it at the time.. :(
grr..
mounts
Postby jon015 » Thu Jan 18, 2007 3:11 pm
i had the same clunking noise, monroe strut mounts fixes the problem, but i had aftermarket suspension, tokico's on teins.
Jon
jon015
Re: mounts
Postby woa_its_j3ff » Thu Jan 18, 2007 3:33 pm
jon015 wrote:i had the same clunking noise, monroe strut mounts fixes the problem, but i had aftermarket suspension, tokico's on teins.
Jon
the monroe strut mounts will it work for stock struts?
cuz i have a stock suspension right now
Postby Ruski » Thu Jan 18, 2007 3:38 pm
i had the something even when i replaced shocks and springs.. went back and tightened the top hat nut and problem solved try tightening the nut
Postby woa_its_j3ff » Thu Jan 18, 2007 3:40 pm
Ruskimafia wrote:i had the something even when i replaced shocks and springs.. went back and tightened the top hat nut and problem solved try tightening the nut
where is it located?
im not good with suspension work. so help a noob out a bit
Postby Ruski » Thu Jan 18, 2007 7:07 pm
all the way in the rear you have to pull everything.. rear deck back seats panels everything its basically located behind the rear seat in a corner hard to get to with out pulling everything out
heres the tutorial
http://www.solaraguy.org/viewtopic.php?t=29372
Postby woa_its_j3ff » Thu Jan 18, 2007 7:26 pm
Ruskimafia wrote:all the way in the rear you have to pull everything.. rear deck back seats panels everything its basically located behind the rear seat in a corner hard to get to with out pulling everything out
heres the tutorial
MOTHERF<KER :evil: :agrue: :o :onfire: :evil:
Postby Ruski » Thu Jan 18, 2007 7:57 pm
sorry dude no matter you'll have to pull it out if you want a drop or try to fit it.. to me it sounds just like what i had a clunking sound.. like the rear hat is loose so i thought new suspension will help everything was done right but the clunking came back one side that i didn't tighten all the way so re tightened it and its stopped Great Success "Borat"
Postby woa_its_j3ff » Thu Jan 18, 2007 8:10 pm
Ruskimafia wrote:sorry dude no matter you'll have to pull it out if you want a drop or try to fit it.. to me it sounds just like what i had a clunking sound.. like the rear hat is loose so i thought new suspension will help everything was done right but the clunking came back one side that i didn't tighten all the way so re tightened it and its stopped Great Success "Borat"
i feel it coming from the whole car lol.
oh well, looks like ill be up to do this in the spring. ill do it when the weather is good out.
Postby Ruski » Thu Jan 18, 2007 8:15 pm
hmm the whole car ?? try to isolate the sound maybe all shocks are blown but i doubt it how many miles u got ?? mine was only the rear
