SolaraGuy.com • View topic - Codes Codes Codes.. Need some advice
Postby Ruski » Tue Jan 23, 2007 1:28 pm
well i have a 00 solara with 81k on it. For the past year i had my check engine on. Codes P0441 P0446 P0440. i have reset it multiple times each time it comes back. So far i have replaced gas cap Nothing. i have read some stuff about the VSV valve and the Charcoal canister.. Any advice or suggestions will be helpful.. I'm a Student so don't have $$ to spend on random guesses on what can fix it.
Thanks in advance
Postby Solarafreek » Tue Jan 23, 2007 1:54 pm
Solarafreek
Postby Midias » Tue Jan 23, 2007 2:11 pm
New gas cap (from dealer) if that does not work new charcoal canister.
Postby Ruski » Tue Jan 23, 2007 6:57 pm
yea i was thinking bout the canister but its 250 bucks.. any way of cleaning it ??
Postby Ruski » Wed Jan 24, 2007 1:47 pm
Any way to clean it or test it ???? and is it the small little canister on the drivers side front cross member by the suspension under the hood ???
Postby Midias » Wed Jan 24, 2007 1:56 pm
if you have a 4cyl it is porbably not the problem
If you have a V6 is is under the rear of the car. Get a shop manual to learn diagnostics.
Postby Ruski » Wed Jan 24, 2007 2:10 pm
its a V6 ill look under the car soon just to make sure the tubes are on tight
Postby TOYODRIVER01 » Wed Jun 13, 2007 3:36 pm
I Have a 4CYL
having the same problems...
any ideas..?
TOYODRIVER01
Postby jhenty » Wed Jun 13, 2007 3:40 pm
theres no where near enough details here to form an accurate solution, and no you cant clean charcoal canisters and they rarely fail. Have someone diagnose your car instead of throwing money at it guessing the problem. I can help you out more if you'd like, pm me.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Heads Up
Postby JMSinMaryland » Wed Jun 13, 2007 6:57 pm
PM me. Jon.
JMSinMaryland
