SolaraGuy.com • View topic - Starting up the car when its warm
Postby viper1400 » Tue Jan 23, 2007 3:52 pm
I have been having a really weird problem. When I go to start up the car in the morning when the engine is cold, there is a little bit of hesitation but the car does start up and idle at a good 1200-1500rpms. The problem is that if I turn off the car for about 5 minutes or less and then try and turn it on again, it hesitates and only idles at around 600rpms then it sounds like the engine is choking and the engine dies in like 5 seconds.
Anyone ever have a problem like that or know what might be going on? I was thinking either spark plugs (havent replaced them for about 80k mi) or the thermostat that I got installed a little while back...maybe neither? Please help...this is pissing me off.
"I'll get it when i have the money..."
viper1400
Postby indiglosolara » Tue Jan 23, 2007 3:56 pm
Idle Position Sensor might be going bad. Very common problem for the solara and camry...
I've had this go back on my Camry and I know of a few members who have had this problem with there solara's...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Anonymouse » Tue Jan 23, 2007 4:06 pm
Any check lights?
'99 SE V6 5 Speed Black, 8000K HIDs top and bottom
TRD Sport Muffler, Eibach Pro-Kit, K&N Drop-In
Anonymouse
Postby viper1400 » Tue Jan 23, 2007 4:09 pm
just my ABS...which i do need to get fixed soon...damn F$&^ing expensive ass cables :evil:
viper1400
Postby Eye8Pussies » Tue Jan 23, 2007 8:01 pm
clean your iac with throttlebody cleaner
you can also turn up your base idle to help fix this and let your iac sensor catch up to your readings
