SolaraGuy.com • View topic - Brake Warning Light Issue - 2000 Solara SLE
Postby danh » Sun Jan 28, 2007 7:47 pm
My brake warning light on the instrument cluster comes on intermittently. Brakes appear to be operating normally. Any ideas as to what is causing this?
danh
Postby Midias » Sun Jan 28, 2007 8:19 pm
check your brake fluid level
Postby RichD978 » Sun Jan 28, 2007 9:02 pm
^^ what he said
RichD978
Postby danh » Mon Jan 29, 2007 7:13 pm
Thanks, guys. Added brake fluid, seems to have solved problem!
danh
Postby un0john0fodg » Thu Feb 01, 2007 6:25 pm
yeah that happened to me too!! brake fluid solved it :D :D
un0john0fodg
Postby krook » Fri Feb 02, 2007 3:40 am
keep in mind too guys that your brake pads may need changing soon. if your brake pads are gettin' thin, your brake fluid naturally is going to dip below the reservoir's sensor (giving you that intermittent flashing of the "BRAKE" light). just pouring more brake fluid is a temporary fix.
start lookin' for pads soon so you know where to get them when you need it.
http://cgi.ebay.com/ebaymotors/Hawk-HPS ... enameZWD1V
krook
