SolaraGuy.com • View topic - Auto HVAC interchanged with Manual HVAC
Postby campfire9 » Tue Jan 30, 2007 7:59 pm
I am really surprised that no one apparently has tried to determine whether the auto HVAC will interchange with the manual especially because so many of you opted for the SE rather than the SLE. Here is a picture of the SLE rear female power connection with the car power cables.
Look at the number of pin that are connected to the power cables. I would think they would be the same as the manual rear female power connection. I can't believe that Toyota would make two separate and different cables. I also assume that the manual HVAC does all the same things as the auto.
Is the manual HVAC the same size and shape as the auto? If it is, then IMO they should be interchangeable.
campfire9
Postby Ruski » Tue Jan 30, 2007 8:02 pm
the auto has many sensor that go along with the system.. this topic i believe was already coverd
Postby Jai_Jai_Binks » Wed Jan 31, 2007 9:49 am
Is it doable, Surely it is. But for the price of a unit + work (i'm guessing the numbers here) - but for 300-400 I'd rather get a some wheels than auto climate control.
Postby campfire9 » Wed Jan 31, 2007 12:12 pm
Jai_jai_Binks I purchased a auto HVAC for $50.00 when I changed the color of the lights. Log onto car-part.com and you will find many dealers with a wide variation of prices. Go for it.
campfire9
Postby campfire9 » Wed Jan 31, 2007 12:14 pm
Jai_jai_Binks I purchased a auto HVAC assembly for $50.00 when I changed the color of the lights. Log onto car-part.com and you will find many dealers with a wide variation of prices. Go for it.
campfire9
Postby Ruski » Wed Jan 31, 2007 12:16 pm
the unit its self is cheap what about sensor and labor.. dont think the sensors are built into the unit.....correct me if im wrong
Postby campfire9 » Wed Jan 31, 2007 5:03 pm
There are no sensors that I am aware of as far as the HVAC unit is concerned. Its strictly plug and play. Take out four screws and unplug the connectors from the back and you are holding the HVAC in your hand.
campfire9
Postby SirMacDaddy » Wed Jan 31, 2007 5:11 pm
If you get this to work campfire9, please post a tutorial on it...i've been trying to do this for a long time but never had the time or knowledge to get it completed....
SirMacDaddy
Postby Ruski » Wed Jan 31, 2007 7:20 pm
^^ What he said try it dude it would be a great mod Let us know
Postby campfire9 » Wed Jan 31, 2007 7:39 pm
Sorry guys, my Solara is an SLE so I already have the Auto HVAC
campfire9
Postby Ruski » Wed Jan 31, 2007 7:42 pm
Damn guess some1 else is gonna have to try it
Postby SirMacDaddy » Wed Jan 31, 2007 8:08 pm
i would try it in a heartbeat....if someone gave me the automatic controls :D
SirMacDaddy
Postby Nyyankees3511 » Wed Jan 31, 2007 8:44 pm
The auto climate has a cabin sensor, and a sensor under the key slot .
Nyyankees3511
Postby Ruski » Wed Jan 31, 2007 8:57 pm
i knew there was sensors some where i was gonna do the conversion for a friend.. When i used to own an accord. there more work then just the connectors.. but would really like to see someone do it
Postby MCOjerry » Wed Jan 31, 2007 8:59 pm
Nyyankees3511 wrote:The auto climate has a cabin sensor, and a sensor under the key slot .
Didn't know about the sensor under the key slot, but you are certainly correct on the other sensor. It's located next to the headlight sensor on the dash.
Campfire, if you have the SLE, then you should surely see the sensor on the dash. Without it, I doubt the automatic climate control would work well...
