SolaraGuy.com • View topic - lights dim
lights dim
lights dim
Postby woa_its_j3ff » Thu Feb 01, 2007 8:50 pm
so today as I was getting ready to leave the library, I noticed my headlights would dim a little bit when I pushed very lightly on the gas. This is while my car was parked.. I didn't have much of my electronics on (radio, leds, etc).. All that was on, were the headlights (obviously), instrument panel lights, plug-in navigation and radar detector..so I was just wondering. Note, the headlights didn't dim significantly, just a little bit. is this normal? let me know .. thanks.
jeff.
Postby Ruski » Thu Feb 01, 2007 8:53 pm
same thing happens to me, if i pull up all the windows lights dim. when sub is on and hits hard lights dim
Postby woa_its_j3ff » Thu Feb 01, 2007 8:54 pm
Ruskimafia wrote:same thing happens to me, if i pull up all the windows lights dim. when sub is on and hits hard lights dim
hrm so I guess it must be normal..
Postby 99V6solaraSE » Thu Feb 01, 2007 9:07 pm
yea same happens here...
99V6solaraSE
Postby Sp33d » Thu Feb 01, 2007 10:10 pm
its VERY normal for our cars to do so. ive heard older guys with ground wire kits and whatnot still having the same trouble. its a genetic default of almost all toyotas.
-mark
Sp33d
Postby woa_its_j3ff » Fri Feb 02, 2007 9:02 am
so you dont think it's like some sort of significant power that's being drawn from the car right?
Postby Yanks0114 » Fri Feb 02, 2007 4:14 pm
woa_its_j3ff wrote:so you dont think it's like some sort of significant power that's being drawn from the car right?
No - we only have an 85(?) amp alternator which is barely large enough to power the stock accessories in the car. Additionally, depending on the engine's RPM, the alternator will produce less power.
...I moved this to gen1 general, not sure what section you wanted this in.
Postby woa_its_j3ff » Fri Feb 02, 2007 5:55 pm
. :( aiyya. time to upgrade the battery then.
Postby netherland24 » Fri Feb 02, 2007 6:30 pm
no upgrade altenrator... more amps more current load.
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
