SolaraGuy.com • View topic - ebrake indicator light???
Postby sahuddleston » Fri Feb 02, 2007 1:47 pm
i have an auto, and when im driving my e-brake indicator light comes on and off periodically. it only happens every once in a while, but its been happening more frequently. any ideas?
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby Solarafreek » Fri Feb 02, 2007 1:52 pm
When is the last time you had your brakes done?
Solarafreek
Postby TRUBirdman12 » Fri Feb 02, 2007 1:54 pm
^^ ya when was the last time you replaced your brake pads. That happened to me when my brakes were worn, i thought there was something wrong with my e-brake, but its just time to get the pads replaced!
TRUBirdman12
Postby sahuddleston » Fri Feb 02, 2007 1:58 pm
been a year and half. i replaced the rotors and pads at that time only like 20k miles though
sahuddleston
Postby bassthrive » Fri Feb 02, 2007 2:00 pm
in addition to checking brake pad wear, check the level of your brake fluid, you may need to top off.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Midias » Fri Feb 02, 2007 2:05 pm
I would go with brake fluid it is probably sloshing around and intermittently tripping the sensor..
On a side not just because you drive auto does not mean you should not use your e-brake. Keep using it so nothing rusts in place from disuse.
Postby ThatVietGuy » Fri Feb 02, 2007 2:29 pm
180 spin turns help with that :drinking:
Oh, yeah, and parking too :P
ThatVietGuy
Postby trd628 » Fri Feb 02, 2007 2:33 pm
I had the same problem and took it in to have the brakes checked (they were under warraty with Midas at the time, BTW never using them again) they said it was just low brake fluid. I went home bought some brake fluid and put it in. The light has been off ever since. Except when the ebrake is on.
trd628
