SolaraGuy.com • View topic - Removing Fender corner lights and Bumper
Postby Orefus » Sun Feb 11, 2007 8:18 am
What tools will i need for this? Im buying everything today, and im going to my freinds garage to work on the damage. I need to remove corners, bumper, fender.
Orefus
Postby Midias » Sun Feb 11, 2007 8:28 am
Metric socket wrench set 8mm -17mm
Flat and phillips head screwdrivers
22mm socket for the lugnuts
That should get it done
Postby neo6205 » Sun Feb 11, 2007 11:44 pm
You'll also need at least a 10 in socket wrench extender. There is a bolt that goes from the bumper into the inside of the fender. You can only get a really long socket wrench into it.
Also, when you're removing the 2 bolts on the bottom of fender right near the jack point be very careful not to shear off the bolts. I did it on 3 of the bolts for the fender and had to drill them out. Coulda been becuase it was like -10 below 0 out but whatever.
Good luck
neo6205
Postby mettler » Tue Feb 13, 2007 8:53 am
you also need to get some lock/push bolt plastic things to replace the ones that you have to take out. but, it is easier to get these after the fact since you can bring them with you to autozone or wherever and match them up. This is on the front bumper. That was the worst part about taking the bumper off.. and those little bolts that were previously mentioned. If I remember correctly, I removed the sidelights in order to get to those bolts.
http://www.facebook.com/pages/Ice-Dragon-Cooling/139536759426738
mettler
Postby Orefus » Sat Feb 17, 2007 8:02 pm
will i need to jack my car for this procedure
Orefus
Postby Midias » Sat Feb 17, 2007 8:04 pm
if you take off the tire YES but the factory trunk jack should do the job.
Postby Orefus » Sun Feb 18, 2007 4:33 pm
where exactly are the jackpoints, behind the front tire?
Orefus
Postby krook » Wed Feb 21, 2007 12:24 am
Orefus wrote:where exactly are the jackpoints, behind the front tire?
uuuuhhh yeah. check the little picture on your jack
krook
Postby mettler » Thu Feb 22, 2007 11:33 am
I didn't jack mine up to take the front bumper off. You will have to get under the front of the car though
mettler
Postby ClassySolaraGuy » Thu Feb 22, 2007 12:06 pm
A Chilton manual might come to your benefit.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
