SolaraGuy.com • View topic - Rattling passanger seat
Postby Candyman » Wed Feb 14, 2007 7:07 pm
Hi,
Does anyone know how to fix a passanger seat that is rattling. This only happens the seat is empty. I just seems loose.
CM
Candyman
Postby woa_its_j3ff » Wed Feb 14, 2007 7:12 pm
maybe the seat mount is loose. make sure seat is attached to the bracket firmly. i had that on my passenger seat too when i bought the lara back then.
Postby Nyyankees3511 » Wed Feb 14, 2007 7:14 pm
CM its a common problem in our solaras. You are going to have to put it in different positions and you will finally get it to minimize. Usually it rattles a lot if the seat is all the way back. Good luck.
Nyyankees3511
Postby unbalancedwood » Wed Feb 14, 2007 9:10 pm
Yeah, its a common thing with me too :(
I have to put it one up from the furthest position.
unbalancedwood
Postby shocar4 » Wed Feb 14, 2007 9:58 pm
candyman...where are you located?
shocar4
Postby akora12 » Wed Feb 14, 2007 10:53 pm
good luck...mine rattles in almost any position, especially in a burnout...it's an expensive fix from what I'm told
Postby Jai_Jai_Binks » Thu Feb 15, 2007 9:48 am
That was one of my problems in my 100K mile update. What has worked for me (i don't know it may be different for your car??) is this:
1. Get on your knees and tighten all the bolts and screws and ensure the track is tight too.
2. use some lubrication in the track as well.
3. just don't place your seat in the fartest front or back settings...this seems to help me out the most.
Thanks for the help
Postby Candyman » Sat Feb 17, 2007 8:57 pm
I think I have to live with it until the spring. Then I will take the seat out and sort things out.
CM
Candyman
Postby Dawgz » Sun Feb 18, 2007 12:23 am
i had that rattling a while back, i dont get it any more...., i was gonna try to fix it but it just went away...and yes it came from the seat cause i would put my hand firmly on the seat and the rattling would stop, as soon as i lifted my hand it would start up.
