SolaraGuy.com • View topic - Oxygen Sensor Location
Postby Hansel » Thu Feb 15, 2007 9:55 pm
I should start off by saying that I have a 99 V6 SE 5 speed and I love it. This is easily the best car I've owned. But, recently my check engine light came on and I got the code P0141. So I'm wondering which of the o2 sensors is bank 1 sensor 2. I changed the one on the exhaust manifold that is visible when you open the hood and the one on the other exhaust manifold has been changed recently too. I just wanted to make sure that it is the one after the cat before I drop the money to fix it. Thanks.
Hansel
Postby Ruski » Fri Feb 16, 2007 8:04 am
this should help you a little. Bank 1 sensor 2 is the sensor in the back of the engine close to the firewall
http://techinfo.toyota.com/public/main/whatstis/rm.pdf and try reading this http://us.toyotaownersclub.com/lofivers ... /t380.html
Im not a hundred % correct so if im wrong please correct me
Postby siennasc98 » Fri Feb 16, 2007 9:31 pm
02 sensors location on a V6 3.0 Liter 1MZFE engine:
Bank 1 Sensor 1 > sensor - RH exhaust manifold, just above the flange (Firewall side)
Bank 1 Sensor 2 - sensor after the catalytic converter
Bank 2 Sensor 1 > sensor - LH exhaust manifold, just above the flange (Radiator side)
siennasc98
