SolaraGuy.com • View topic - Poly or Rubber Bushings?
Postby kaarona1 » Mon Feb 19, 2007 7:20 am
I am going to buy new sway bar end links and control arm bushings. I have researched and found that the poly is the "sports upgrage" but some people have said that they have trouble with them drying out. Any suggestions on the poly or should I just go with new rubber bushings? The rubber are $20 and the poly are $7.
kaarona1
Postby SleeperSolara » Mon Feb 19, 2007 9:05 am
Poly mounts will only die out if you don't take care of them.
If you put Lithuim Grease on them make them last longer.
Postby kaarona1 » Mon Feb 19, 2007 9:53 am
So with the poly, you grease them when you install them. Then do you have to regrease every so often?
kaarona1
Postby SleeperSolara » Tue Feb 20, 2007 3:18 pm
kaarona1 wrote:So with the poly, you grease them when you install them. Then do you have to regrease every so often?
Yeah your suppose to grease them when you install them, what idiot wouldn't?? :lol:
Depends on how often you have to re-grease them.
