SolaraGuy.com • View topic - HELP gen1 gauge cluster HELP
Postby sahuddleston » Tue Feb 20, 2007 12:54 pm
guys, i replaced my gauge bulbs, when i plugged the 3 harnesses back into the back of the gauge cluster i turned the lights on to see if they were working. nothing came on. my CEL, door open and all those lights came on but the bulbs didnt. i turned the car on and off just to check. my headlights work fine, just the gauge bulbs and turn signals dont work.... HELP!
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby lilm » Tue Feb 20, 2007 1:40 pm
u replaced them with bulbs right....not led's?
lilm
Postby sahuddleston » Tue Feb 20, 2007 1:47 pm
yes, got the bulbs from the dealer. im taking the white ones out and putting stock ones in
sahuddleston
Postby ---CAMRAZY--- » Tue Feb 20, 2007 2:00 pm
Did you twist them in??? Airhead.... LOL
Postby lilm » Tue Feb 20, 2007 3:11 pm
run a test light or volt meter to make sure its getting juice
lilm
Re: HELP gen1 gauge cluster HELP
Postby Jai_Jai_Binks » Tue Feb 20, 2007 3:27 pm
You did throw away the burnt out bulbs. and a volt meter is a wise idea if everything seems to be plugged in and twisted.
Postby sahuddleston » Tue Feb 20, 2007 4:21 pm
dont have a volt meter. ive taken bulbs out and in a few times and never had this problem before. like i said, all of the warning and indicator lights come on when i start the car, the bulbs for the back of the gauges ust dont light up...
sahuddleston
Postby Hsakuragi » Tue Feb 20, 2007 4:56 pm
u sure the hardness are tight enough?
also check if the back of the cluster (the green sheet) to see if the metals (the gold color) are fried
Hsakuragi
Postby sahuddleston » Tue Feb 20, 2007 6:05 pm
green thing looks like it did before. harnesses are clipped in. could i have blown the fuse? where is the fuse located?
sahuddleston
Postby sahuddleston » Tue Feb 20, 2007 7:08 pm
is the fuse box for the gauges located inside or under the hood???
sahuddleston
Postby krook » Wed Feb 21, 2007 12:23 am
stupidrunner54 wrote:is the fuse box for the gauges located inside or under the hood???
should be behind your coin pocket on the left side of the steering wheel. check your owner's manual, too. it'll tell you which fuse box contains the fuse you're looking for
krook
Postby sahuddleston » Thu Feb 22, 2007 6:18 pm
idea... maybe someone can tell me if this is it. could it be that my gauge bulbs and turn signals arent working because my warning/hazard lights are unplugged as well?
sahuddleston
Postby krook » Thu Feb 22, 2007 8:03 pm
stupidrunner54 wrote:idea... maybe someone can tell me if this is it. could it be that my gauge bulbs and turn signals arent working because my warning/hazard lights are unplugged as well?
HELLL YEAHHHH....wtf!?!! lol
krook
Postby SolaraGuy22 » Sat Feb 24, 2007 9:44 am
You gauge bulbs should work fine with the hazard clip out. Blinkers won't though.
I'd check the fuse for sure and reseat the clips in the back.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby unbalancedwood » Sat Feb 24, 2007 10:00 am
AutoZone...voltmeters for rent
unbalancedwood
