SolaraGuy.com • View topic - FOGLIGHT HELP PLZ!!!!!!
Postby jvsoccer1788 » Tue Feb 27, 2007 4:47 pm
i just got my new aftermarket foglights for my 2004 solara and i had to cut off the factory foglight bulb harness, and then i went to put one of the new foglights in and both new and foglights will not turn on, i have reaplaced the foglight fuse below the stearing column, and they still wont turn on, is there another fuses or something im am doing wrong?
jvsoccer1788
Postby Sebas007 » Tue Feb 27, 2007 5:02 pm
One things is sure...is you will miss good advice of Gen 2 guys since you post it in Gen 1 forum ;)
You really had to cut your fog light harness ???
Postby jvsoccer1788 » Tue Feb 27, 2007 5:23 pm
sorry about that ya i did
jvsoccer1788
Postby NeFaRiOuS_SLE » Fri Mar 02, 2007 9:37 am
You might've reversed the polarity; test it with a voltmeter first... You risk shorting out stuff if you just go and reverse it anyway.
