SolaraGuy.com • View topic - Tire Pressure
Tire Pressure
Tire Pressure
Postby Jackass-Jeff » Tue Apr 01, 2003 7:31 pm
02 SE w/ Stock 15s and stock Bridgestone Potenza
The manual says 29, but my friend's dad (auto mechanic for about 30 years or so) said it's better to have it slightly more inflated... so I'm at about 35 PSI right now (max for the tire is 44 psi)... any bad things about having a higher psi ?
Thanks in advance
1GR-FE ftw!
Jackass-Jeff
Postby 20SoLaRa02 » Tue Apr 01, 2003 7:43 pm
umm maybe u should run lik 32 cold air. 35 seems a bit high to me but it might be ok. i'm running 34 psi but im' suppose to be at 32. with more air in ur tires u get less traction but it might help ur tire life a bit. at the same time it might also cause uneven wear of the tires...but that i'm not sure about.
20SoLaRa02
Postby NASTY » Tue Apr 01, 2003 9:00 pm
go with what the manual says, maybe a little over
another thing, make sure you check/adjust pressure when the tires are cold (ie: havent been driver for at least 3 hours, or over 2km)
'01 SLE V6
NASTY
Re: Tire Pressure
Postby Flipside909 » Tue Apr 01, 2003 9:58 pm
xravexboix wrote:02 SE w/ Stock 15s and stock Bridgestone Potenza
Thanks in advance
35 is actually perfect. Make sure this is COLD PSI...not psi readings taken after driving a few mins.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Jackass-Jeff » Tue Apr 01, 2003 11:22 pm
yea cold psi (about 1 hour 30 mins after driving for just 20 minutes)
Thanks Ryan
1GR-FE ftw!
Jackass-Jeff
Postby 4banger » Mon Apr 07, 2003 3:36 am
I remember reading something in the manual about increasing the pressure if you plan to drive over 100mph. I don't remember what psi they said.
Silver '99 Solara SE 4cyl.
4banger
