SolaraGuy.com • View topic - Turing stearing wheel = RPM increase?
Postby unbalancedwood » Tue Mar 06, 2007 2:07 pm
Not sure if its a problem, but was very curious about it.
When i was in Park i moved the stearing wheel to the left, the RPMs went up ~200
Also turned it right, did the same thing.
Is there somthing wrong with my car?
I'm soon to be replacing the valve cover gasket (small leak), drain and filling my transmission fluid a few times, oil change was done a few thousand miles ago (synthitic)...is it time to flush the power stearing?
THANKS!
unbalancedwood
Postby PXLpainter » Tue Mar 06, 2007 2:10 pm
It's called Power Steering - LOL! ;)
Just like the A/C - it draws power and automatically increases the RPMs to accommodate and not stall the engine under load.
Postby unbalancedwood » Tue Mar 06, 2007 2:37 pm
Thanks PXL...i just wasent sure, never noticed that before.
How often should I replace the power stearing fluid?
unbalancedwood
Postby rollaevo99 » Tue Mar 06, 2007 2:42 pm
unbalancedwood wrote:Thanks PXL...i just wasent sure, never noticed that before.
not really sure how often you'll replace it.....but make sure always check that you don't go below the minimum.
Postby SolaraBlue » Tue Mar 06, 2007 2:45 pm
most places will check it for you when you have your oil changed...
Postby NeFaRiOuS_SLE » Tue Mar 06, 2007 8:55 pm
No, it's just power compensation... Unless you want it to go UNDER, stall and lurch a good foot or 2 chirping the tires, or unassisted steering (i.e. thrusting the steering wheel HARD) I'm sure you probably don't want either to happen... Take it from a person who has driven a '67 Bug.
Postby Ruski » Tue Mar 06, 2007 9:06 pm
yea thats normal.. mine does it too don't pay to much mind to it
