SolaraGuy.com • View topic - Wheel Hub Bolt size/ axle bolt
Postby lazyboyz69 » Sun Mar 11, 2007 8:41 pm
After 1 hr of searching, I was wondering if anyone knows the bolt size that connects the wheel hub and the axle, i need to replace a cv boot, so i need to take out the axle.
I know someone did a tutorial on changing transmission fluid, and that person took out the axle.... i just can't find it....
Thanks alot solaraguys!
lazyboyz69
