SolaraGuy.com • View topic - Tranny Problem
Tranny Problem
Tranny Problem
Postby happy_aggies » Fri Apr 04, 2003 2:25 pm
Y'all,
It just happened 2day that it's hard 4 me to shift to R.
When it shift to R, it makes a thumping noise,
and when reversing, it makes noise. :cry:
Any idea what to look for?
(I suspect is the tranny slipping problem?)
My Solara is a bit less than 60k.
Do you think It's still covered under warranty?
happy_aggies
Postby krazeee1707 » Fri Apr 04, 2003 3:28 pm
I'm not too sure on what exactly the problem is..you think it could of been caused by the accident???
krazeee1707
Postby happy_aggies » Fri Apr 04, 2003 3:48 pm
I don't think it's caused by accident.
It has been almost a week, and it just started.
happy_aggies
Re: Tranny Problem
Postby Flipside909 » Fri Apr 04, 2003 4:33 pm
Yes you are still covered under warranty. As long as you don't surpass that 60,000 on the odometer. When's the last time you had your tranny fluid flushed? If you haven't done so, it would be best to get it done ASAP.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Yanks0114 » Sat Apr 05, 2003 5:45 pm
Happy Aggies, you have the SC and an upgraded pulley correct. I'm not sure the symptons of tranny slipping, but it makes sense that it is slipping. If that is the case just switch the pulley back and go into toyota and have it replaced under warranty.
Postby Guest » Sat Apr 05, 2003 5:59 pm
uh oh... does it happen all the time? or just sometimes? I seem to have the same problem (~14k miles) but it occurs only occassionally if I park on a hill
=x
Guest
Postby Flipside909 » Sun Apr 06, 2003 12:06 am
Anonymous wrote:uh oh... does it happen all the time? or just sometimes? I seem to have the same problem (~14k miles) but it occurs only occassionally if I park on a hill
=x
are you even S/C'ed? If not that's a warranty issue you need to take up with your local Toyota dealer.
www.clublexus.com
Flipside909
Postby Jackass-Jeff » Sun Apr 06, 2003 10:00 am
(i was the guest, above, i forgot to log in)
I'm not S/C'd hehe... I only get the "thump" if I parked on a pretty hill going on the downward slope while putting it into Reverse
1GR-FE ftw!
Jackass-Jeff
Postby Yanks0114 » Sun Apr 06, 2003 12:17 pm
xravexboix wrote:(i was the guest, above, i forgot to log in)
That just sounds like its because there is stress on the tranny. I get that too when on hills. Hold your foot on the brake and keep the ebrake up and it should help. Also be sure when you are on hills to always use the ebrake.
Postby Jackass-Jeff » Sun Apr 06, 2003 9:44 pm
i always use the e-brake...
i meant "pretty steep hill" not pretty hill... :oops:
1GR-FE ftw!
Jackass-Jeff
Postby happy_aggies » Mon Apr 07, 2003 9:42 am
Should I un-install my cat-back as well?
happy_aggies
Postby Yanks0114 » Mon Apr 07, 2003 10:23 am
happy_aggies wrote:Should I un-install my cat-back as well?
Nope, catback won't void the warranty because it doesn't change the emissions. :D
Postby Flipside909 » Mon Apr 07, 2003 10:50 am
You may want to depending on how picky the dealership is. When they see a few things like being lowered, aftermarket wheels, and exhaust...they usually turn you away. Actually putting an aftermarket exhaust system technically voids your warranty because you're altering the factory exhaust system of your Toyota. Now if it was concerning the law, yes a catback is legal because you don't touch/alter the catalytic converter in anyway.
www.clublexus.com
Flipside909
Postby Yanks0114 » Mon Apr 07, 2003 10:56 am
But shouldn't it only void the exhaust warranty. It should have no effect on the transmission.
Postby Flipside909 » Mon Apr 07, 2003 10:59 am
Depending on how technical the dealership wants to get, the exhaust will void your powertrain warranty.
www.clublexus.com
Flipside909
