SolaraGuy.com • View topic - NEED HELP ASAP
NEED HELP ASAP
NEED HELP ASAP
Postby woa_its_j3ff » Sun Mar 25, 2007 8:01 pm
okay so here is my problem.
My fuses work. connections are tight. bulbs arent burnt.
and yes i checked ALL my fuses, bulbs etc..
BUT.. when i turn on my car, my parking lights turn on like they hsould BUT my turn signals dont work. hazards dont work. basically, they are just steady on. and they dont blink like they are supposed to. the blinkers in my instrument dash dont blink either....
I called Reggie, John and s15, about the problem but they aren't really sure. im hoping someone can help me out.. because i know that electrical problems are very expensive and I dont really knwo waht to do.. i dont want to bring it to the dealership just yet but at the same time i dont have much time..
any info regarding this please let me know asap. thank you.
Postby Ruski » Sun Mar 25, 2007 8:04 pm
First of all back track on everything you have done to the car that is electrical.. It can be a simple ground or something that is totally screwed !! what have you touched or done that is electrical lately ??
Postby DaTwUnKrAziEpInOy » Sun Mar 25, 2007 8:06 pm
Maybe a relay is busted if your signal just stays on.
DaTwUnKrAziEpInOy
Postby Ruski » Sun Mar 25, 2007 8:09 pm
take fuses out that deal with the lights and replace with a spare one
Postby MCOjerry » Sun Mar 25, 2007 8:15 pm
Good luck. That is a strange problem. When you find out what it is, post up so that if it happens to anyone else, they know what to lok for.
Postby PXLpainter » Sun Mar 25, 2007 8:17 pm
Done any recent work on electrical or did it just start happening all of a sudden?
Postby woa_its_j3ff » Sun Mar 25, 2007 8:18 pm
ive not done anything to the car lately at all. the last thing i had done to the car was led BUT.. that was months upon months ago in the beginning of winter. there are NO loose connections of any kind...
I DID bring my car to toyota yesterday to get my driver side window fixed and when i drove home that day the signals still worked fine but it just today on the highway they stopped working.... I really hav eno idea...
I already replaced all the fuses just in case. STILL dont work..
Postby Ruski » Sun Mar 25, 2007 8:19 pm
J3ff might be those neons back firing :lol: if you still have them installed
Postby Ruski » Sun Mar 25, 2007 8:21 pm
take it back to toyota and tell them they screwed up... the connections in the door where the motor get power might be bad
Postby trdkamuri51o » Sun Mar 25, 2007 8:22 pm
hehehehehehehhehe.... so many electrical problems ehh mark????
okay there are a few fuses that u should check under the dash and in the engine compartment to be sure..
have u installed gauges or neons??? (cough rice!!)
jk check the wiring on those..
if all else fails get a can on blinker fluid!!!
trdkamuri51o
Postby DaTwUnKrAziEpInOy » Sun Mar 25, 2007 8:23 pm
LOL ^^
DaTwUnKrAziEpInOy
Postby woa_its_j3ff » Sun Mar 25, 2007 8:27 pm
aight im not in a fu_king mood to be played around with today. either you give some useful advice or shut the f_ck up.
wiring and everything on my lighting is fine.
where can i find this blinker fluid?
Postby Ruski » Sun Mar 25, 2007 8:28 pm
Ruskimafia wrote:. the connections in the door where the motor get power might be bad
Recheck, triple check everything you have done that is electrical !!!!!!!
take a volt meter out and start testing
Postby woa_its_j3ff » Sun Mar 25, 2007 8:29 pm
^ i checked. i spent 3 hours at the car meet checking. with everyone else helping.
only thing i havent checked is the blinker fluid crap. i dont know where that is.
Postby trdkamuri51o » Sun Mar 25, 2007 8:31 pm
woa_its_j3ff wrote:aight im not in a fu_king mood to be played around with today. either you give some useful advice or shut the f_ck up.
did i not give u serious advice?? you can check the fuses 30 times over and im going to tell u check them.. also check your fuc|<in emergecy light switch to make sure its properly connected..
and if all else fails a can of blinker fluid helps,
trdkamuri51o
