- netherland24
- SolaraGuy Supporter
NeFaRiOuS_SLE wrote:Might be a carryover from the narp valve! Blinker fluid IS linked to the narp valve, and it just might be cylinder reversion causing a perimeter voltage fluctuation and causing it to reverse the functions as well! Tell me, does your headlights come on instead of the tails when you step on the brakes (in some cases the accelerator)? DON'T tell me it's the accelerator, because that's the most severe reversion!
