SolaraGuy.com • View topic - Brake Booster
Brake Booster
Brake Booster
Postby dc3886 » Thu Mar 29, 2007 8:30 am
I'm told I'll need to replace my brake booster soon, has anyone had to replace one and if so how much did it cost. I called Toyota and got a price quote on the part and they said it will be $830. I found a remanufactured one online for $200. It looks like it'll be a pain to replace.
dc3886
Postby ---CAMRAZY--- » Thu Mar 29, 2007 8:41 am
I haven't heard of anyone needing to change their Master Brake cylinder....
Who told you that lie?
Postby dc3886 » Thu Mar 29, 2007 10:11 am
My mechanic friend says I have a vaccum leak in my brake booster.
dc3886
Postby NeFaRiOuS_SLE » Thu Mar 29, 2007 12:07 pm
How many miles do you have on your car? Usually those last for a long time; someone I knew replaced it for the first time at 201,000 miles and I had to help her drive it to the dealership with a heavy reliance on down-shifting and braking at the last few feet.
Here's a few simple tests:
1. Find a less-frequented stretch of road; if there is light traffic, put your blinkers on. Lightly step on the brakes; does it stay in the same location?
2. With the car stopped and ignition on, step heavily on the brakes and see if it stays in the same location after a minute.
3. With the ignition off, pump the brakes heavily until it only moves about 1/2" and lean on the brake pedal for a minute and see if it sinks or not.
If any of the 3 happen, your friend is honest. If not, sorry; he/she is full of it (I've been given a list of repairs I don't need by a "friend").
Re: Brake Booster
Postby bronzemaxell » Thu Mar 29, 2007 12:33 pm
dc3886 wrote:I'm told I'll need to replace my brake booster soon, has anyone had to replace one and if so how much did it cost. I called Toyota and got a price quote on the part and they said it will be $830. I found a remanufactured one online for $200. It looks like it'll be a pain to replace.
$830 sound about right for a new dealer brake booster, i bought an used one on ebay for $25, turn out i don't even need it, in my case, it was the check valve and vaccum hoses at fault, i replced for around $30, problem went away.
bronzemaxell
Postby Eye8Pussies » Thu Mar 29, 2007 1:21 pm
yup...dealership prices are around there over here in Canada too
and milt- I'd say that master cylinders go a lot more often than boosters....never seen a booster go...but my dad's master cylinder just went a number of months back. but I think it was just a seal inside....not really worth the time to rebuild though.
and unfortunately, I didn't have the time to do the work myself either.
Postby dc3886 » Thu Mar 29, 2007 6:45 pm
I only have 81,000 miles on my car so maybe I'll try and replace the valve and hose before I buy the brake booster. I really wouldn't mind saving the money.
dc3886
Postby JavaJoe_2 » Thu Mar 29, 2007 7:58 pm
I bought a check valve from a pick-a-part-salvage yard....cost me a buck.
You can usually see if the lines/rubber is bad
JavaJoe_2
