SolaraGuy.com • View topic - Engine Miss
Engine Miss
Engine Miss
Postby Wild Bill » Tue Apr 10, 2007 7:10 pm
Hi everyone, I have a 2001 Solara v6 , twice in the last week the engine started to run rough and almost stalled at idol. Once when I pulled into a gas station after a 3 hour run on I75 and the other time when I slowed down to turn into my driveway. The car was fully warmed up both times.Any advice would be welcome .
I am new to this board and I thank everyone in advance.
Regards Bill
Wild Bill
Postby onefiend » Tue Apr 10, 2007 7:21 pm
how many miles do you have on the car?
have you had a tuneup?
2007 Camry SE V6
onefiend
Postby DatSRBoi » Tue Apr 10, 2007 7:22 pm
Tell us more. With what you say I can think of 10 things off my head.
Postby Wild Bill » Tue Apr 10, 2007 7:43 pm
Hi Again, I just purchased this car and I have no service records. It has 130 k miles on the clock. It has a sticker on the timing cover that says the timing belt was serviced at 60k.
Thanks
Wild Bill
Postby ClassySolaraGuy » Tue Apr 10, 2007 8:02 pm
Spark plugs...Check them first.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby Eye8Pussies » Tue Apr 10, 2007 11:50 pm
iac - affecting your idle
if its dirty or malfunctioning, it won't be able to adjust for the slowing down of the engine speed after its heated up
Postby Wild Bill » Wed Apr 11, 2007 5:13 am
What is an iac and any idea how much it costs to replace?
Wild Bill
Postby (K) » Wed Apr 11, 2007 10:20 pm
From what you're saying, that sounds like a vacuum issue.
It only happens when you slow down and steer right? My mother's Ford Windstar does that ALL the time now. It used to only do it once in a blue moon so we didn't pay much mind to it, now it'll do it when you try to turn AND brake at once.
It'll probably be more apparent when you start to brake hard and make a turn.
Get your hoses checked before you actually start replacing anything.
(K)
Postby Jai_Jai_Binks » Thu Apr 12, 2007 9:24 am
Eye8Pussies wrote:iac - affecting your idle
^^^ DING DING DING...thats what popped in my head as the first suspect.
Additionally, i would also:
1. To timing belt/drivebelts + water pump + teermostat
2. Sparks and ignition wires
That should be suffice to keep it running for another 130K miles.
