SolaraGuy.com • View topic - Removal and Service of EGR Valve
Postby Wild Bill » Sat Apr 28, 2007 12:02 pm
Hi All, Can anyone explain how to service the egr valve. I think that mine is sticking open once in a while.
2001 Solara v/6
Wild Bill
Postby SolaraBlue » Sat Apr 28, 2007 12:42 pm
welll... i can tell you its not a cheap part...
http://pa.partsandaccessories.com/parts ... ve&dp=true
Re: Removal and Service of EGR Valve
Postby bronzemaxell » Mon Apr 30, 2007 6:48 am
Wild Bill wrote:Hi All, Can anyone explain how to service the egr valve. I think that mine is sticking open once in a while.
2001 Solara v/6
i think there is a total of 5 small screws, 3 on top, and two on bottom which is a paint to reach, if you have the proper socket and extension and WD40, you should be ok, i really don't know how to service the egr valve, it just has a tiny plastic rod sticking out. replacement for an OEM geninue toyota egr part cost around $160 to $180 online at www.toyotaoemparts.com, i would recommend getting two metal egr valve gaskets replace as well incase it might leak air if you reuse the old gaskets.
bronzemaxell
Postby Wild Bill » Sat May 12, 2007 5:42 pm
Update! I replaced the EGR Valve ( Auto Zone $169.00 ) It seems to have fixed the problem.
Bill
Wild Bill
Users browsing this forum: Google [Bot] and 10 guests
