SolaraGuy.com • View topic - Question about shifting
Postby nkx1 » Sun Apr 13, 2003 11:33 am
Is it bad for our 5 speed cars to downshift while braking? I know it seems kind of redundant to downshift and brake at the same time, but sometimes if I have to come to a stop pretty fast, it seems to slow the car down quicker.
Also (totally unrelated and maybe a little trivial), what kind of gas cap do you guys/girls have? On mine, it's a cheap feeling black plastic one with white writing on it. My old car (Integra) had a really solid feeling metal one. Just wondering if the previous owner might have lost the original and just bought a generic one. :fadein:
2001 SLE, Diamond White Pearl
nkx1
Postby Luc » Sun Apr 13, 2003 11:46 am
I used to downshift also, but after hearing a clip on TV saying that it would be cheaper to replace brake pads than transmission-related parts, I've resorted to braking more. Of course, if you are downshifting to run some ricer off the road, by all means, do it. :lol:
1998 S/C'd 1MZ-FE A/T
Luc
Postby Elfumador » Sun Apr 13, 2003 1:21 pm
I always downshift and use the brakes . it aint bad for the tranny just don't going 60 and downshift to second :drinking:
Elfumador
Postby Peter » Sun Apr 13, 2003 1:21 pm
if ur going downhill, downshift, if ur going up, break, and if its just regular road, i usually switch off, but i tend to downshift more, its more fun
Peter's "Black Sheep"
Visit Black Sheep
Peter
Re: Question about shifting
Postby Flipside909 » Sun Apr 13, 2003 4:18 pm
nkx1 wrote:Is it bad for our 5 speed cars to downshift while braking? I know it seems kind of redundant to downshift and brake at the same time, but sometimes if I have to come to a stop pretty fast, it seems to slow the car down quicker.
Downshifting aka engine braking is fine epsecially if you are drving a long downhill grade or etc. This is especially useful on mountain canyon carving runs. The last thing you wanna do is boil up your brake fluid and lose your brakes to fade. Never ride your brakes going downhill.
As for your gas cap, it's a stanton made unit. All Toyotas use a black plastic cap with White text warning label on it.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby NASTY » Sun Apr 13, 2003 7:41 pm
i took my drivers training in standard and the dude always taught me to downshift when slowing down/stopping, but only after youve applied the brakes (because they should do most of the stopping). also, that way when you can speed up again youre ready to go (ie: coming up to a red that turns green)
'01 SLE V6
NASTY
Postby Kenn157 » Sun Apr 13, 2003 11:41 pm
I also downshift and brake. The braking is usually just lightly.
Had a 99 Solara SE V6. Had a 06 Tacoma. Now I have a 2008 Camry SE V6
Kenn157
Postby STR8PYP » Mon Apr 14, 2003 1:11 pm
WTF? OK, first of all, define downshifting. If it means you just plop it into a lower gear and let the clutch rev the engine up, you're wearing down the clutch BIG TIME. Second of all, engine braking (a result of downshifting while braking) puts a LOT of wear on the engine as well, effectively decreasing the life of the engine. Third, it may not seems like it, but it DOES put wear on the transmission, because when engine braking, the only thing slowing down the car are the transmission gears, so by putting additional pressure on the gears to slow down the car, you're adding to it's wear since it's already used to accelerate the car! I used to downshift during braking a lot during the first two years after I learned how to drive manual, but after attending racing schools I NEVER EVER downshift the car without rev matching the motor, and that is only done in necessary situations.
Besides, think about how much brake pads cost, compared to replacing your clutch! Doesn't make sense. I'd rather wear down my pads than put additional wear on my engine and tranny.
Hey, if you don't believe me, keep doin it...when you start feeling the effects of the wear and tear you're applying to the engine, clutch, and transmission, I hope you'll remember this.
SC
STR8PYP
Postby solaraguy777 » Mon Apr 14, 2003 4:25 pm
when u down shift let say from 3rd to 2nd when u hit the clutch while ur right foot is on the brake take ur foot off the brake while the clutch is in hit the gas the so the car rev is up when the rev is up let the clutch out its a lot smoother and u have to downshift when u brake.
Ram air intake w/ k&N filter, Trd exhaust,
Hp racing evo 18's, Tokico/Eibach combo.
solaraguy777
Postby STR8PYP » Mon Apr 14, 2003 4:42 pm
solaraguy777 wrote:when u down shift let say from 3rd to 2nd when u hit the clutch while ur right foot is on the brake take ur foot off the brake while the clutch is in hit the gas the so the car rev is up when the rev is up let the clutch out its a lot smoother and u have to downshift when u brake.
Or...just keep your foot on the brake, and take your car out of gear while braking. You'll save gas, you'll save your engine, and you'll definitely save your transmission. The only wear you'll be putting on the car by ONLY using your brake is the brake pad! That's a VERY cheap item compared to the rest. Do the math.
SC
ps and taking your right foot off the brake pedal to rev the motor up throws off the balance of the car and nullifies and benefit to rev matching, which is mainly used to maintain balance on the car during shifts.
pps why must everything be so complicated these days?! Keep it simple. You wanna stop, use the brake. You wanna go, use the gas and clutch to change gears. Nobody's special...driving is driving.
STR8PYP
Postby Yanks0114 » Mon Apr 14, 2003 6:30 pm
LOL. Agreed. Your statement about brake pads being cheaper than a tranny is so true. You brakes are there for a reason :wink:
Postby Flipside909 » Mon Apr 14, 2003 8:32 pm
I'll agree with steve on most of his statement. I disagree when you're decending down a long mountain road or hill. Something that you East Coasters wouldn't understand from long downgrade elevations from 5,000 feet and above.
www.clublexus.com
Flipside909
Postby STR8PYP » Mon Apr 14, 2003 11:39 pm
Flipside909 wrote:I'll agree with steve on most of his statement. I disagree when you're decending down a long mountain road or hill. Something that you East Coasters wouldn't understand from long downgrade elevations from 5,000 feet and above.
For the record, I never disagreed with Ryan's position on downhill engine braking. It's helpful in SOME situations and a downhill trek is one of them. :) Just wanted to clear it up.
SC
STR8PYP
Postby Flipside909 » Tue Apr 15, 2003 12:27 am
Thanks Steve! :D When are we gonna play a round of golf with Dwayne and whoever?
Oh and Carlo...I still wanna go to Mira Vista for a round! :D
www.clublexus.com
Flipside909
Postby cdssolara » Tue Apr 15, 2003 1:52 am
The invitation's always open; just let me know when you're up here again. I may be selling my membership, so you better make it soon!
cdssolara
